18th c, /19th c, clamps?
Phil in NNJ
>We see lots of tools from the 18th and 19th centuries, but I've never seen what they used to clamp parts together. Were parts clamped? Does the use of hot hide glue obviate the need for clamps? Dovetails would be one way to reduce clamping, but, despite the availability of wide boards, there are pieces that are edge-glued, as well as other joints that we would typically clamp such as mortice and tenons. So, what did they use? Just curious.
Thanks
Re: 18th c, /19th c, clamps?
Re: 18th c, /19th c, clamps? *LINK*
Pam Niedermayer, Austin, TX
>Alburnam's Archive is a great place to start. Here's the section on clamping.
Pam
Clamping & cramping
Bob Rozaieski
>Here's a pic of the clamps at the Anthony Hay Shop in Colonial Williamsburg.
Roy Anderson
>Here's a clamp I saw on E-Bay that is on my project list to copy. Note the end piece needs to be turned by 90� to work right.
Spanish Luthier's Clamp
Roy Anderson
>This is one of my favorite type of clamps that I have never tried to use.
This thread's been kind of cool
>I've got some clamps like some of those pictured, from my uncle (who gathered a lot of antiques with his wife). Nice to know they could be early 19th century.
Warren in Lancaster, PA
>As others have mentioned there were a variety of clamps in the 18th century. But certainly clamps were used a whole lot less at that time. One can see an old desk or a chest with just a few places where a clamp would even be helpful. And hide glue can be used without great clamping pressure or just with rubbing. In old work you are not likely to see a table top with seven boards glued together or a case side with four boards joined together. And hardly ever 4X4s glued up from thinner stock.
Re: Spanish Luthier's Clamp------WebKitFormBoundar
Rick W------WebKitFormBoundary4KtE29u+KvOK62Gq----
>I have used these clamps for joining guitar tops and backs.
They work very well.They clamp the pieces together with adequate pressure, and also hold them flat.
They should work just as well joining any thin, wide pieces of wood.
Rick W
------WebKitFormBoundary+52BwMfK9vPq8Rru
Spanish Windlass?
Ron Bauman
>I have for years used this system when gluing up odd shapes. It consists of a rope loop with a broom handle at some point. You twist the rope with the broom handle drawing the loop tight. I used it on many occasions to re-veneer the skirts of round tables. Blocks of wood placed every few inches insured equal pressure as I increased the tension. I googled same, but didn't come up with any pics or descriptions.
Brian Coe
>Exactly. Some specialized clamps and a few general ones, but much less need than in a modern shop for general work. I worked for 10 yrs.+ in a hand-tools only 18th century style shop, and we did large cabinet pieces with only a few clamps in the shop. Carcass and drawer dovetails rarely needed clamping, and almost all the mortice and tenon joints were pinned and/or drawbored, so they were self-clamping once the hide glue was applied and the pegs driven home.
Re: 18th c, /19th c, clamps?--Question
Wiley Horne--So. Calif.
>for Warren and Brian and all,
I like hide glue, a lot. But here is something I don't understand, and I know you guys are experts. How much clamp pressure is best when using hide glue, say for a panel glueup? I have heard that applying heavy pressure--like for yellow glue--will risk starving the joint if you're using hide. Also, hide seems to shrink as it dries, pulling parts together to some extent.
I know the question is vague, so here is something more specific. Assume the edge joint planing is good, meaning the seam between the boards will disappear under ordinary hand pressure, and you're using hot hide glue, what's the best clamping routine in your experience--rubbed joint, some pressure, lots of pressure? Say, 2 or 3 eight-inch boards that are four feet long being edge joined.
Thanks for any insight!
WIley
Hide glue
>I don't see any danger of starving the joint when clamping hide glue. The danger is like having the glue set up before you have the chance to squeeze the excess. I am reluctant to recommend hide glue for edge gluing on a large panel. It is hard to get glue on, get it together, lined up and rubbed or clamped fast enough. Unlike dovetail or tenon joints, a panel does not have to be taken apart for repairs and can be thought of as a single piece of wood. Actually just about always looks better if it is a single piece or a wide piece with a small add on.
In gluing an edge it is helpful if the room is very warm or the edges are heated. In the winter I put the gluepot on the woodstove and, shortly before gluing, the boards on also. If you are rubbing, the glue can be a little thinner than usual and rubbed until sticky. I think you would want to do lots of short joints like 6-12 inches before trying something big.
I had a bottle of Franklin liquid hide glue around 1983. I can't remember why I didn't like it.
John Aniano in NJ...
>Phil, et. al.,
Check out this fellow's website - all you ever wanted to know about wooden clamps. Mostly mid to late 19th century, but hey, you asked!
No affiliation, just an interested web searcher...
John
http://theclampguy.info/
Adam Cherubini
>If you look at the clamps they had, it seems they didn't have the types of numbers required for the work we do. My guess is that clamps fell into one of two prime uses; holding work so you can work on, and veneering. Otherwise, I think your view is correct. Hide glue typically doesn't require/benefit from clamps. This is true even for veneer at times. Other parts were typically mechanically fastened, m&T, dt, nails, all of which don't require clamp assistance.
Also in this is the sense that work was done, parts were put together and work continued. They probably didn't have the clamp this up, put on this finish and come back tomorrow sense.
So the "one can never have too many clamps" addage is just one more indication of how little we have in common with the most basic approaches of 18th c woodworkers.
adam
None
Adam Cherubini
>Wiley,
It's true that high clamp pressure will starve HG joints. I've done it. For long joints I much prefer to use PVA and the 8 4' pipe clamps I bough to build my first work bench. But I've been practising with HG long joints. I've had some limited success with test pieces of carcass sized joints. You want the glue really runny. A single long clamp placed in the center of thejoint (length wise) is sufficint to keep the boards together for the hour or so when the joint susceptible to being knocked apart.
I'm a firm believer in sprung joints, but a lot of spring won't work well with hide glue. I also advocate match planing. But it's possible they prepared edges with try planes with curved blades. I would think even a few thousandths would help maintain the bondline thickness and lead to a success HG joint.
Adam
Re: None
A few thousandths of what?
Pam
Gap
Adam Cherubini, NJ
>The camber on a try plane may produce a few thousandths of gap (sag). If you put a try square (even my wooden one) there would be a little light under it. That gap gets doubled if both boards are prepared the same way. You'd also probably lose some of that if you clamped, as the edges would compress.
Adam
Thanks.
Re: Hide glue
Jerome Bias
>I have had fairly good results gluing up 4-5' tops using hot hide glue. I usually put a very very slight spring in there. I use slightly runny glue and I was taught to clamp them as though I was clamping a yellow glue glue-up. Lots of clamps fairly tight, but not tight enough to cause the clamps to bend.
I always do a dry run of my glue up. If things seem a little rough or if the room is colder than I like, I'll subdivide my glue-up in to two or more parts.
I don't know if it is correct or not but I was taught to put glue on both edges. The squeeze out leaves lots of drips. The dog loves any that make it to the floor.
So far my tops have done well, but then again I also put a sliding dove tail batten in there to safe guard things.
Jerome
