Funny pliers
David Miller from Iowa
>For what is this used?
thanks, David
Funny pliers
thanks, David
Re: Funny pliers
>Used for crimping the spark plug wires on Duesenbergs, Cords, Auburns, and the occasional Marmon (that's Marmon, not marmot - different critter altogether). Known among mechanics as "chicken beaks" for the distinctive shape of the crimper.
No, I actually have no idea at all, though they do look like some kind of crimper. Where do you find these things? Is the back corner of your shop some kind of treasure trove, and was it that way when you moved in, or did it get that way thanks to you?
Pie crust crimper!
Tony - Memphis
Saw Set?
Hank Knight
>Maybe for a large timber saw? My best guess.
Looks like...
Brent Smith in Montreal
>The mega version of what they use to remove staples used to close surgical incisions. Could be it's a tool used to remove large staples on transport boxes?
Metal duct crimper
Al Goldstein
>It could be a tool for crimping the end of a section of metal duct so that it could be inserted into another section.
Or maybe it is a medieval torture device.
Probably not, at least not for ductwork
>For one thing, the crimping part is too short - crimpers usually crimp 1" to 1-1/2". For another, the crimp would be too extreme.
Might be a lead, though - a specialized tin crimper for some industrial application.
Waiting for Todd Hughes - it will turn out to be a dynamite wire crimper used during the Crimean War, or something like that, and Todd will own seven and have seen about 100.
Bill, tin bender for six months some years back and still thinks he knows about it, the danged fool.
Re: Funny pliers
Graham Montgomery
>That tool is agricuture. There was a type of horse drawn corn planter that used a "seed tripper" mechanism to trigger the point at which the seed was planted. A long wire that had what looked like washers spaced at regular intervals along its length was strung across the field and each time the trigger on the planter encountered one of these tripper washers, seed was released. The idea was that if the rows were equally spaced and if the plants in the row were equally spaced, the field could then be cultivated both east to west and north to south thus dealing with weeds not only between the rows but also between the plants in the row. I suspect the tripper wire was prone to breaking and this tool was intended to ease the job of making repairs.
Although not barbed wire, seed tripper wire often appears in barbed wire collector's displays.
Re: Funny pliers
>I showed the image to a tinsmith friend of mine and he said they were after Rowe 1886 patent for a stove pipe crimper, although this one is not a Rowe.
Stephen
I stand (sit) corrected
>they sure looked like too short a crimp for tin to me - but this, like every trade, has manifold byways.
Re: Funny pliers
>Thanks Graham, and the plot thickens.
Interestingly, I bought this at a farm auction, along with a spool of "check wire" which, curiously, was in the same lot, and which you describe as the planter trigger wire. So your analysis rings true, but I can't discount Stephen's crimper assertion either.
Thanks for your input - I'll try to google Rowe's crimper, but my gut (which is often wrong but always feels right) just doesn't "feel" like a crimper - I have a set of downspout tools and this is just not close enough, at least for tonight - but let me research the Rowe's patent angle.
David
Re: Funny pliers
Graham Montgomery
>David,
Your follow up message made me realize that I had sort of misspoke in my earlier reply.
I referred to "seed tripper wire". I've heard it called that and that's certainly descriptive of what it does but your response made me recall that "check wire" is the CORRECT name for the item, a term I had forgotten.
The fact that you found the roll of check wire and the tool togther at the sale indicates that whoever organized the sale knew what went with what...... not always the case.
I'm certainly no expert on the subject, but from what I've read, there were a number of different variations of this stuff, probably related to the number of manufactures of planter machines. I described one version I have seen that had washer like devices spaced along the length of the wire. Another I have seen had each section of the check wire terminated in a twisted on, nearly perfect round loop with an ID of about 1/2". I'm probably going way out on a limb here, but I'd guess that the roll of check wire that followed you home from the sale is of that type, and the tool you have is what made that loop
