Brass wheel brush
Brass wheel brush
Brass wheel brush
Dave (Arlington, VA)
>Hi all -
Just a quick reality check question. In the past I've cleaned up the grit and rust on my flea market-find planes by hand using just razor blades, green Scotch pads (with WD 40), and elbow grease.
I am starting to get impatient, but didn't want to screw any of these planes up by doing anything rash. My thought was us use a brass wheel brush in the hope of speeding up this process. I can't recall any mention of these over the years, but we've got so many experienced tool restorers here I am sure that someone has tried this approach or has a view of whether something like this might do more harm than good.
Any thoughts would be most welcome.
Regards -
Dave
Re: Brass wheel brush
Moses Yoder
Moses Yoder
>The only thing I use a motorized wheel on is screw heads and threads. If you use them on the side of a plane it shows up as overcleaning with light scratches. Electrolysis works fine for me and I think makes a good tool in the end.
>Thanks, Moses.
I guess I'll hold off on the brass wire wheel. I had wondered if the brass would scratch the plane.
I haven't used electrolysis because I don't have a car battery recharger and it didn't seem right to get one just for the occasional flea market find. I am soaking the screws and washers in Evaporust and the rust seems to be coming off them quite well. This is the first time I have tried Evaporust. But it is $10 per quart so I've been using it judiciously as I experiment with it.
Thanks for the advice.
Regards -
Dave
roninkokomo
>I think there are some buffing wheels ( with compound) that would do a good job and not leave the tiny scratches
Dominic in Bucks County PA
I use them
>Dave,
I use a soft, medium, and sometimes hard brass wire wheel brush installed in a drill chuck (at my lathe).
I've cleaned up several dozen planes (as people here can attest) and never had ANY problems with scratching. I HAVE had problems with little brass wires ending up in my shirt! :>) So now I wear a leather apron (with the ties in the back).
Now that being said, I would NEVER use this method on a highly collectable plane. I would use a less intrusive way a like citric acid or Evaporust bath for removing the rust. Or even just leave it alone (if it was worth that much I'd be afraid to mess with the patina!)
See ya around,
Dominic
Their you planes, do what you want to them...
Scott Burr in Ben Lomond CA
>Unless like Dom said, (in my words) if they have value don't. I've used steel wheels, bead blasting, and other torturous methods. It realy doesn't matter.
Hell I just got done bead blasting a Stanley 51 and re-japanning it. A collectible plane? Yes! Whas it before I got my paws on it? No it was a mess.
I now have a very serviceable, very nice looking plane (like new!) that I could probably sell for 2-3 times what I payed for it, that ain't gonna happen!
It's a personal decisions. Just don't do what I did to that 51 to a NO.1...
Re: Their you planes, do what you want to them...
Marv
>Scott,
Did you actually re-japane it or did you just paint it? Japanning is a very involved process that includes oven curing at a high temperature.
Marv
