A finishing question - old cherry...
John Aniano - in central NJ...
>Hello All,
I need to deepen the color of a number of ~1840 turned cherry spindles to even them out. They have been stripped of their old black matte finish. There are 48 spindles altogether in the staircase and maybe 15 need to a be a bit darker. There is some sapwood present in a few of the spindles. Might potassium permanganate, or some similar chemical do the job? I worry that the wood, being so old, will react unfavorably using chemicals like these. How about using Transtint dyes in alcohol? Or should I look at other options?
I'll ultimately finish the spindles with Tried and True "varnish-oil" - the turned cherry newel post has two coats already and looks great.
TIA,
John
