A good product *LINK*
Wiley Horne--So. Calif.
>Hi All,
Am in the midst of putting together a small bench for a small location, and want to thank all those offering suggestions.
For a base, I ended up with Lee Valley's Cast Iron Table Legs, linked below. These turn out to be stout and satisfying. I can highly recommend them if they meet your functional need. Wilbur's suggestion--thanks Wilbur!
The only thing you have to do to get up and running is make the stretcher that connects the two leg assemblies, and then screw on a top. I face-glued two 2x6's to make the stretcher, and it is very stout--zero movement. The stretcher has to have a center channel (~13/16" square) to take the tensioning rod and connector nut. I used a soft wood (redwood) which is easy to hand plough for the channel--would not have been much fun with hardwood, but that old 19th century plough was lots of fun with the soft wood. McMaster Carr delivered the top, 2-1/4" maple, and it turned out well. Very flat, and while it's finger-jointed butcher block, the outside strips on the long sides are continuous (not jointed). I can recommend this top if you have a similar need. John Boos & Co. is original supplier. Will be adding an LV twin-screw vise on the end. Making the wrap-around apron now.
Observation and mini-rant: Lee Valley ships these cast iron legs with the basic hardware for attaching a top. The heavy screws for the top are #3 Robertson (square drive). Folks, I can't for the life of me understand why square drive Robertson's did not become the universal standard. They are so much better than Phillips, it's ridiculous. They do not cam out. Drive these larger ones with a brace.
