French Feet
French Feet
French Feet
John Hoffman
>Hi all,
I am trying to understand how to make French Feet. I saw an example at the recent WIA of using a wedge for the side part of the foot, but don't understand the front piece. I know you can cut the curve from solid and that one side of the front piece is glued to the side part but what happens to the rest of the foot? Isn't it hanging in the wind unattached to the front of the chest?
Thanks
John
Re: French Feet
Re: French Feet
Warren in Lancaster, PA
>French feet are just fancy bracket feet. The underlying structure is similar to straight bracket or ogee bracket. There are several ways to get the flair, but the front part of the foot is the same as the side part. The two pieces are mitred or sometimes just butted against each other and then shaped to match. I think you would want to be comfortable making straight bracket feet before trying French feet.
Re: French Feet
Re: French Feet
John Hoffman
>Thanks for the response. I understand that the front feet are glued to the side feet. I don't understand what happens with the rest of the front foot. Does it just join a cross member as part of a frame? If so doesn't if stick out from the case the thickness of the top of the foot and isn't this a problem?
Hope I am not being confusing.
Regards
John
Re: French Feet
I know all about them....
Bill Tindall, E.TN
>Took a class in the Headley's shop last year just to learn how to do them. You may call me for how to make
Re: French Feet
Re: French Feet
>A front foot is made of a front piece, a side piece, and various blocking. The foot is under the carcase, so there is no top of the foot sticking out. The top of the foot is flush with both the front and the side of the carcase.
The back feet are sometimes flared only on the side with the backs straight. And sometimes flared on the back side also.
Re: French Feet
I don't agree
Bill Tindall, E.TN
>I have set several museum alarms off crawling under pieces examining French Feet and they are all made like I learned at Headley's shop with minor variation. The case side is kerfed and wedged and the front is overlayed.
Re: French Feet
That's still a gorgeous piece.
Pam Niedermayer, Austin, TX
