We value your privacy.
>So I have a lathe I'm trying to bring life, please see link.
As it states I have 1/3 HP Squirrel that can move at 1750 RPS, provided I keep it jacked on espresso. But what diameter pulley do I put on it's wheels shaft? The lathe as a 4 way pulley with diameters of 1, 1-5/8, 2-3/8 and 3 inches.
>I would try to find the same size pulley that's on the headstock but mount it on the motor so the small pulley lines up with the large pulley on the headstock.
>Whatever is on the motor has to be a step pulley also. The math doesn't work out to get the speeds you mentioned with the pulley sizes on the step and a single pulley on the motor.
>So you're getting that critter running, eh? Good to hear.
The basic formula is M x D1 = S x D2
where
M = motor rpm
D1 = diameter of motor pulley
S = spindle rpm
D2 = diameter of spindle pulley
Given any three values, you can calculate the fourth easily enough. There are online calculators, too: type in "pulley diameter calculator."
From what little I know of lathe work, a) maximum spindle speeds over 3000 rpm aren't much used, and b) having moderately slow low speeds are desirable. The larger the swing of the lathe, the slower the lowest speeds should be, since the issue is feet per minute at the circumference of the piece being turned. The turning crowd could give you a good sense of what speed ranges would be good for that lathe.
Matching your current pulley sizes will give you a max spindle rpm of 5175, if I did my math right, and a minimum of 575 - both extremes are a bit fast. If you've got the room, maybe you should put a larger pulley on the lathe; or maybe a smaller one on the motor, if you can get one that small.
Some turners will install an idler pulley that you operate with your foot or knee. This gives you a cheap variable speed control as you are turning. The idle allows the belt to slip in the V pulleys.
I would go on the Turners forum and chat with those guys.
>Those guys take great pride in what they do and the tools and machinery they use to do it. Most of them enjoy sharing their knowledge and skills. They do some fantastic creations. I know little about turning, but I do know that if you get hooked on it, it can lead you into an entirely different realm of woodworking. Can you say "addiction"?
Would like to see some multiple pictures posted in here of your lathe setup and shavings being spewed out all over your floor.
>You wouldn't recognize it. I had it bead blasted. I found one of those "crazy English polishers" in Santa Cruz. He has a great shop. You should see his old brass fire extinguisher collection. He does amazing work. I had him strip a 608 and the #51 frankplane. Anyway I japanned the nuts and screws. Painted and baked a kinda matching gray enamel. I have before and after pics. It's mounted on a piece of plywood with a hinged piece to hold the mot... er... Squirrels. If it's not offensive, I'll post some pics. After all I'm not coordinated enough to walk and chew gum so to speak.
You taken advantage of the chisel? Hope so!
Scott, yet again on fire watch as Bonny Dune is ablaze one more time this year.
>The setscrew on a step pulley is generally on one of the center "steps." Motors I've seen have all had enough shaft - did I send you one with too short a shaft?
