A55 Smoothing Plane
sharpening a draw knife
Bob in Green Bay
>Looking for best advice to sharpen a draw knife.
I am testing the waters in green woodworking a bit. I like the draw knife sharp. I can do it, but am guessing I am not efficient.
I am sort of a water stone guy but am open to suggestions. I mostly have been doing this around the campfire as a leisure activity.
Help appreciated,
Bob
Re: sharpening a draw knife
I use a couple methods...
Alan DuBoff
>Bob,
I do it a couple ways...
This also depends on the type of drawknife you have also, there are bevel up and bevel down.
The flat side can be worked with a stone, and do that before moving to the bevel. Make sure the flat side is flat, IOW. I like to work the flat side from side to side, with either sand paper or a stone. Once this is flat, move on to the bevel.
For the bevel side:
1) use scary sharp on a stick, just wrap some sand paper on a stick and sharpen by pushing the stick from the rear of the blade, so it abrades over the edge. Keep your fingers pointed down behind the blade, to keep your hand from going past the rear of the blade. NEVER sharpen into the blade, a sure way to leave your fingers on the floor...:-/ Also, be very careful not to push in front of the blade and pull your hand back.
2) secure the stick to a bench or shaving horse and pull the blade across the stick/paper. I like to move the drawknife sideways as I do this, so that the entire surface is sharpened as you pull. I have done this in a pinch by using an f-clamp on a bench to sharpen a friend's drawknife.
Either of those methods can be used with a diamond stone or even a water or oil stone. Diamond stone works well if you have one.
Maybe someone else will recommend something else.
Cheers,
Alan
Re: I use a couple methods...
Todd Hughes
>Belt Sander....I use a big 2 X72 inch one but a smaller one will work too.
I touch them up using just a regular whet stone, I don't know much about it and don't have too but it's one I found in a bunch of junk and keep on my bench for quick touch ups.
I hold the left handle in my left hand with blade facing me bevel up and then push right handle up against the base of my vise. Then just run the stone over the edge in a figure 8 motion back and forth. Then flip over and take burr off the back..Sometimes I spray stone with some WD40 sometimes I don't.
Pretty fast and easy to get one real sharp like this....basic common sense sharpening and not much to think about really .
Just go do it....Todd
John L. Blue
>Use a file while it's clamped in a vise.
ThomD
>Belt sander is the best method for knives that have a convex blades. A stips of sandpaper on a soft backing will also work, or a hand held waterstone, or stone of choice.
Re: suggestions
Dave Mount
>Belt sander is good for initial forming, particularly if you have serious nicks to get out. Bench grinder and a light touch works too, but often the handles interfere with other parts of the grinder to make it tough to grind the whole edge. That's the advantage of a belt sander as they will usually allow better clearance for the handles.
Drawknives work best with low bevel angles (e.g., 20 degrees on the primary bevel, with a 5 degree backbevel, see below). Most have much higher bevel angles when you get them. It's common to have to take off quite a bit of metal to get the primary bevel down to 20 degrees. If you're new to drawknives, I probably wouldn't worry that much about this at first, just get the thing sharp and the bevel angle you have. Once you get a sense for the tool you can worry about reshaping the bevel.
For refining the edge on the bevel side, I take a short chunk of 2x4 and cut a groove in it as wide as the blade is thick, and at the same angle as the bevel. When you stick the drawknife in this block, it puts the bevel in a horizontal plane. I then use stones freehand. Because the bevel is now horizontal, it makes it easier to know where the proper stone orientation is -- just make the stone parallel to the bench.
I use diamond stones for curved blades to avoid dishing my waterstones. However, you can also use the edge of the waterstone instead of its face to get around this problem. I use the edges of stones for outcannel gouges for the same reason.
With regard to the flat side, you get better control of your drawknife cut if you put a slight backbevel on, maybe 5 degrees. This should be very short. An added benefit of a back bevel is that you don't have to polish the entire flat side of the knife, as only the back bevel matters.
When working the flat side, the handles will often interfere with using a stone just sitting on a bench, especially for the knives with "dropped" handles (handles that are not in line with the flat side of the blade). To make sharpening easier, take a 2 foot chunk of 2x4 and affix some cleats to one end such that they will hold your waterstone in place. Clamp the other end of the 2x4 to your bench, leaving the end with the stone on it cantilevered out into space. This arrangement gives clearance for the handles. Hone the back bevel by placing the flat side of the knife on the stone, then tip the knife up at about 5 degrees (just by eye) and pull it across the stone like you were using the drawknife on wood (except with little downpressure).
Works for me. . .
Dave
Tony - Memphis
>Oh come on Todd, aren't you going to quote some microns and water vs oil and take pictures with microscopes and such? How can you really be certain your draw knife is sharp without all that. I mean, how did you measure the precise angle? And what is the exact chemical composition of that blade?
Sorry, couldn't resist.
Tony
Kenneth Martin Sacramento
>I use a four inch dia. round Washita(?) stone. It was intended for sharpening axes but works fine for a draw knife.
Ken
>I have one of those stones, too, although it's a manufactured rather than natural stone. Do you oil it?
I've seen pictures of some of the round stones with a groove around the circumference to serve as a warning line - "don't put your fingers past this line." Mine lacks that. If yours does not have it either, do you have any magic tricks to keeping your fingers clear, other than the always-reliable "paying attention?"
roninkokomo
>I use hold the knife in my left hand braces against my left shoulder ( bevel up) and hone with a succession of two or three stones by sliding the stone along the bevel ( horizontally). I stop at 1000 grit for green work.
Works well for me
I have to agree with John
>Drawknives even with laid steel blades are not that hard and can be easily filed (draw filed) to a sharp edge.
Putting them to a stone is a waste of time.
Stephen
>My stone doesn't have a groove so it is "pay attention".
As for oiling, I must confess sometimes I do and sometimes I don't.
Ken
I agree
>I've always used files, followed by an oilstone if it needed to be any sharper than I was able to get it with a file.
There's also some difference of opinion about bevels (bezels). I personally think of a drawknife as a carving tool, so I put a slight rounded back bevel on the flat side and a rather pronounced rounded bevel on the other side. I can't recall which school of thought is from where.
hard!
paul womack
I have a Ward & Payne drawknife that begs to differ on that point.
BugBear
Re: suggestions
ThomD
>By the by, one can get right down to super sharp on a belt sander, the belts start to add up in price though, They even have buffing belts in cork or leather.
For convex edges the best setup is a special platen which has a rubber belt like a tank track that runs over several wheels, very suptuous grinding and sharpening on that puppy. Costs lots too.
