Somewhat OT - Tutankhamen exhibit
>There's a Tutankhamen exhibit at the DeYoung in San Francisco (and, somehow, a simultaneous one at the Children's Museum of Indianapolis; also, one of the exhibits moves on to the Art Gallery of Ontario in Toronto in November). LOML and I went today.
She found all kinds of interesting pottery-related things; you'd think she'd been a potter for over 20 years or something...
Me, I was struck by how many of the statues and other objects are of wood. Generally, the quality of the work is phenomenal (especially considering that they were using copper tools), and the condition of the pieces just as amazing (they ARE 3500 years old after all). Some of the low relief carvings were maybe 1/8" high, or even less, and the ground of the carvings was very very smooth. On one statue, maybe 18" high, you could see the toenails and those little wrinkles toes have at the knuckles. Most wood pieces were coated with gesso, which would tend to smooth over tearout; but even with that, a modern carver would be proud to do work like that. A lot of gold leaf that was so smooth, you could imagine seeing undistorted reflections in it.
On the other hand, I saw some issues that I struggle with: one funerary boat model, which was a solid carving, had some dead vertical end grain where the foredeck and quarterdeck (using Age of Sail terminology here - not sure what the Egyptians would have called it) stepped down to the main deck, and there was lots of tearout, where the wood fibers collapsed from the chisel. Insufficient sharpening, coupled with wood with fibers that wouldn't stand up to the side pressure.
Various woods - some pieces, with some rot or other damage, were clearly a softwood of some kind that resembled second growth redwood. Someone suggested cedar, and, when I researched it on the 'Net, there was discussion of Lebanese cedar. Other pieces looked to be some kind of very fine grain hardwood.
Lots of mortise and tenon joinery, often with amazingly tiny sections of wood, down to 5/8" by 3/4" or so; frequently pinned with, if I understood what was going on correctly, metal pins. One chest had tiny, beautifully done (from the bit I could see) metal hinges. Frame and panel or, more often, what I guess you'd call frame and slat - like assembling a panel from several pieces of wood and forgetting to glue them together.
Even though this was work for royalty, the workers weren't always choosy - while a lot of the wood was dead clear, it was just as common to find pieces with burl or knotty areas with which the worker just struggled through. My favorite was a chair (in the classic shape that screams "Egyptian chair" to the modern eye) on which the back was frame and slat (sides were too). As best I could tell - the chair was in a glass box, so I couldn't get closer than about 24" - the bottom member of the frame was made of a piece of wood that was dramatically narrower on one end - maybe 1-1/2" at one end, 2-1/2" at the other. The slats were adjusted in length to compensate, and angled on the end to fit. There was no visible aesthetic need for this; the paintings and inlays on the chair were all very rectilinear. I suspect the chairmaker had a piece of stock that was great in every way except its width, so used what was there.
Of course, all this was from the perspective of a not very knowledgeable 20th-century guy in the middle of a crowd in not always well-lit rooms (I believe for reasons of preserving the pieces).
I wouldn't drive across country to see it, but if it's near you, it's well worth going.
