Neat vise *LINK*
Neat vise *LINK*
Neat vise *LINK*
Marv
>Pam posted the website a couple weeks ago where this vise was purchased. I received it yesterday and couldn't wait to get it mounted to my workbench.
It's not an Emmert, but for only $136.00 plus $11.50 for FexEx, not too bad. It weighs over 32 pounds.
Somewhere between Taiwan and my back door it got dropped and the shaft for the round crank handle got bent. So much so I couldn't turn it. I managed to get the handle off and straighten the shaft. It works great. I like it.
Marv
Picasa Web Album 4 pictures
Re: Neat vise *LINK*
Purty neat
Re: Neat vise
Wiley Horne--So. Calif.
>Marv,
That really does look to be an excellent tool. It gets the work up in the air, so you have good hand relief from all sides. Plus the jaws open wide enough that you can catch things edgewise to make them more accessible. Pam done good!
Is that a D-12 or No. 12 handle you're working?
Wiley
Re: Neat vise
Marv
>Hi Wiley,
That's a Disston No.12 handle. The D-12,s were made after 1928 and not nearly as well shaped or wheat carved. That particular handle was made prior to 1917.
Marv
Often used by gunsmiths and luthiers... *LINK*
David Barnett - SW FL Gulf Coast
>...you can usually find them from 75USD up. They're great for gunstock carving and inletting. I have 'this' one (link below), but it's been discontinued. Shop around. They're really vereatile.
Luthier's vise
Re: Often used by gunsmiths and luthiers...
Pam Niedermayer, Austin, TX
>There are several versions of this type vise out there, but I finally decided it was worth a few more bucks for the round handle. I haven't bought one yet, just don't have room for it with that Zyliss hogging a bench corner and working well enough for what I need. Plus it's the one and only good present Mom ever gave me. :)
But when the time comes, I'll get the StewMac.
Marv, so glad it's working for you.
Pam
Marv
>Hi Pam,
The handle is not only round but bares against a roller bearing. The fit and finish is pretty good. The clear polyurethane pad bonded to the face of the wood jaws is a nice touch. This kind of polyurethane is nearly indistructable.
The beefy side struts are more than adequate and slide smoothly. The only loosness is the back screw nut that the main screw engages. It is better to be a bit loose, rather than being tight, however it is looser than it needs to be.
There was a couple negative feedbacks on the Wheeler Engineering Pattern Makers vise, but for only $82, ya cain't expect a precision tool. Rather something you might find at Harbor Fright. It's academic though because it has been discontinued, at least at Midway USA. Probably available at other similar online stores.
Garrett Wade has them for $130.00, painted green, but not John Deere green! And no roller bearing.
Marv
