laying out the fret work
Bill Tindall, E.TN
>None of this will make any sense unless you are familiar with the earlier post about three lines below in the threads under "trellis".
The bottom "inlay" pattern was assembled as described by Wiley for the process to make banding. It is assembled like a butcher block and then thin pieces sliced off and glued to a backing piece to make the alternating light/dark bands of the bottom part of the tray side. The top to be fretted was assembled from 3 plies to make it split resistant and this assembly glued to the bottom inlay part. The bottom strip was glued on the bottom of the inlay part and left protruding to provide a stop for the marking template. Laying out the fret work pattern then became a simple matter of scribing the fret lines indexed off the alternating bands of the inlay, again as show in the picture. Now after a simple matter of precisely sawing out the openings the pattern wil be complete. Some practice may be necessary.
Many of you will recognize contributions you all made to this process.
