How to make black oxide coating
Bill Tindall, E.TN
>I bought some cast iron trunk handles from White Chapel. They are a rust red color and I would prefer black oxide. How do I get the black oxide coating on them?
Bill Tindall, E.TN
Re: How to make black oxide coating
ThomD
>http://www.birchwoodcasey.com/
I've used a variety of their products over the years.
>Seems like I read somewhere about heating the hardware with a propane torch and then rubbing motor oil on it - but I've never tried it.
R Payne
>I wouldn't use motor oil. You will need to burn the oil (heat to smoking) and with the various things in oil who knows what you'll be breathing. Wax or cooking oil will do the same.
If you don't mind a little work to get it even, you can also clean it to shiny then apply vinegar or mustard or various fruit juice. If you gently heat that it will speed the process. It will not be very dark at first and it may be blotchy ( any oil on the surface will interfere with the process so clean with alcohol or acetone first). You can apply as many coats as you want to get the effect you desire.
ron
Patrick Gibbons, Katy, TX
>Bill, it's just like seasoning a cast iron pot. Clean the rust off then cover it with cooking oil and then put it in the oven for about an hour. I've also heard of people using motor oil and doing this but I would think the smell would be objectionable.
ThomD
>Those will get you a black finish, but not necesarily an oxide finish.
another opportunity to annoy the kitchen manager!
Bill Tindall, E.TN
>I have been banned from the microwave after setting a piece of poplar afire in it. The black from steaming walnut in the pressure cooker is still there. I was able to buff out the tarnish after using the big stew pot spoon as an anode for rust removal electrolysis. The stains from experimenting with bleaching Wiley's iris dye were successfully removed. So I may be on safe ground to try cooking some "blackened" trunk handles in the oven.
what do you suggest?
Bill Tindall, E.TN
>I would like the handles to be blackish and stay that way and not rusty looking. Do I oven bake or go for the other treatment you suggested.
Re: what do you suggest?
ThomD
>It's probably easier to do the heat blackening than to find BC's stuff locally, if the results are what you want. You can try a gun shop, they will all sell the blueing, though it may not be black enough for you.
http://www.swdinc.com/black_oxide.htm
http://www.finishing.com/faqs/blackoxide.html
http://www.caswellplating.com/kits/black.htm
You don't have to burn the oils in an oven. The last wok I did was done out of doors with a propane burner like a weed and ice burner.
This is where the concept of 'clean dirt'
Wiley Horne--So. Calif.
>comes into play. Suppose an object like the best stewpot spoon has been befouled, blackened, coated in ooze or oven cleaner or suchlike. But then you clean and scrub it all up, and apply not only soap but also desperate home remedies (trying to remove the last traces), followed by more soap and scrubbing (in the kitchen sink, which itself becomes a project). What then results? Is the object now perfectly (meaning 'undetectably') clean? No, it's still blemished, plus now it has deep bright scratches from the various cleaning operations.
But it's clean, doncha see. That's clean dirt, just like on the knees of my jeans. So the object has been restored to goodness.
I practice the above in the mirror, but have never been able to sell it to the Secretary of Interior.
Wiley....waiting to hear further of Bill Houghton's larvae-freezing experiment in his newly-remodeled kitchen.
Re: This is where the concept of 'clean dirt'
Pam Niedermayer, Austin, TX
>It's never clean again. For example, I once had a boyfriend who peed in the bathroom sink. Even though he "cleaned" it, I couldn't stand to touch the sink, much less use it or clean it myself. It was simply ruined. Problem solved by getting rid of the boyfriend and moving out of the apartment.
Pam
To be fair...
>I'd get upset if LOML used my tablesaw as a potting bench, instead of its proper use (piling pieces of wood and other stuff on).
Just finished negotiating a week in the freezer for my new bowsaw, to ensure that the beetle infestation is over; it involved heavy wrapping in plastic followed by two wrappings of heavy duty aluminum foil.
reminds me of the time I stored worms
Bill Tindall, E.TN
>....in the refrigerator. The bait shops always store worms in a frig so when I needed to keep some for an upcoming trip it seemed a good idea to do likewise.
Well, they escaped, or at least some did. They were found in the lettuce where they seemed quite content. This resulted in yet another banning from kitchen appliances.
Ace Karner
>Pam sez "It's never clean again. For example, I once had a boyfriend who peed in the bathroom sink. Even though he "cleaned" it, I couldn't stand to touch the sink,"
What the hell does this have to do with the OP?
I think it's called "digressing"
>and is part of WC's charm, for me.
Off topic posts--General Rule
>Hello Ace and all,
Ace said, "What the hell does this have to do with the OP?"
Answer: Not much. As Bill Houghton indicated, Pam's anecdote was in the vein of my own silly tongue-in-cheek digression. She strayed no further than I did. In hindsight, perhaps I should have thought twice before hitting the Post button.
The WoodCentral policy on digressions in stated in Messageboard FAQs. In sum, W/C allows a lot of latitude, so long as the comment is not religious or political, is not attacking someone else in a direct personal way, nor is unreasonably offending sensibilities.
The climate that Ellis wants to have on W/C is one of tolerance--that we should follow the Golden Rule and give others the same respect each of us wants for ourselves. Ellis is striving for a climate where posters can be themselves, be real, and not be assailed for it--so long as they're not harming others.
In my opinion, my post was not adding much (I was trying for humor, probably unsuccessfully), but then it wasn't harming anyone; Pam's post likewise; and your complaint is OK because you stated it objectively rather than personally ('what does this have to do with the OP?').
To all: Because W/C allows considerable latitude, there will be times when someone crosses our personal line. Please feel free to email me offline, if you get offended. I would appreciate it if we would just take any further on this subthread offline.
Thank you,
Wiley Horne
Moderator
>heat the handles up and plunge them in linseed oil and they will get a nice black coating on the surface.
Stephen
One comment about blueing
>I've used blueing and it makes a very nice black finish. However, it is not a rust inhibitor as the oil process is. I don't know if that's important to you but it's good to know.
how hot?
Bill Tindall, E.TN
>can you estimate a temperature to the metal heat to? Will 550 F in the oven work or are we talking about red hot with a torch?
If linseed oil will work then so will cheaper cooking oils .
Re: how hot?
Craig D
>Bill wrote: can you estimate a temperature to the metal heat to? Will 550 F in the oven work or are we talking about red hot with a torch?
I used the kitchen oven at 450F. If you heat and dip, you get a nice brown, if you bake at 500F, you can get almost black. This steel screw was dipped in BLO. I stuck it back in the oven, turned off the heat and let it bake until cool. It has stayed like this for over six months (it is the locking screw on my marking guage).
Craig
Re: how hot?
Craig D
>Bill wrote: ... or are we talking about red hot with a torch?
I don't know about iron but if you heat steel to red hot and dunk (ie quench), the black oxide layer can't be removed with a wire wheel. I often leave this finish on my chisels.
Craig
Black oxide coatings: hot vs. room temperature *LINK*
David Barnett - SW FL Gulf Coast
>ThomD's suggestion and link to Caswell is the way to go if you want a genuine oxide black and not a charred oil finish. Heated oil over BC's "Plum" bluing can give a nice dark graphite color, but it works better with very dirty motor oil.
Process description (SWD, Inc.)
Re: how hot?
>'If linseed oil will work then so will cheaper cooking oils.'
Linseed oil polymerizes or dries and cheap cooking oils don't, except walnut oil, which is not cheap.
Linseed oil has been the choice for centuries.
Stephen
hotter the better...
John in NM
>I used to know a sculptor who'd do this with linseed oil and a torch. He applied the linseed with a rag, so obvioulsy it wasn't glowing bright. If you oil quench, I'm assuming you know about the fire risk? Get oil hot enough, and it will burn without ignition (one of the only mythbusters I ever saw they were surprised to have this happen and even more surprised when the fire extinguisher wouldn't put it out!).
I think rust bluing will work on cast iron too, more labor intensive, but much less messy in the kitchen. I believe an old style rust blue is more rust resistent than hot bluing and definitely more than cold bluing.
How I do it...
>Bill,
I just wipe on a thin coat of oil, thin as I can get it, then hold it over a heat source, a gas grill, say, until it begins to smoke. Keep moving it about until it goes from tacky to fairly tough and resiny, then add more oil and heat until it begins to blacken. Do this until it you develop a nice charcoal grey film, then heat a little longer until it appears (and feels, when cooled) dry and matte. Then add a topcoat (I use Waterlox, BLO, RenWax, matte Krylon acrylic, whatever). The topcoat makes it look darker.
Oh, heat guns work, too, and a torch with a bushy flame.
The oil coating is a great A&C patina for copper, btw. Substitute peanut oil for mineral and heat until you produce an even silky dark brown. One coat will usually do it. Wax for a topcoat. Dry beeswax rubbed out with a handful of wool will give it a soft glow.
