A bowsaw in the wild! A rarity in this area!
>this is the first one I've seen (and, thus, the first one I bought...).
Looks commercially made, although the toggle made from a scrap of framing lumber and the tensioning line made from shipping twine are probably not OEM. It needs a little work (other pics in attached messages), but for $5 seemed worth it.
It's had some action from what looks like anobiid beetles, visible toward the right end of the cross piece but scattered around (I'm thinking of them as lightening holes) - does anyone know if these can be frozen dead? If so, I'll bag it and put it in the freezer for a few days.
Re: A bowsaw in the wild! A rarity in this area!
The hole for one handle was drilled crooked
>but I suspect I can live with that.
And one tenon is maybe a bit long
>but that will be easy enough to correct.
Should have done my internet research
>According to several sources, freezing temps will kill these beetles - one week at freezer temps.
It also appears they could be anobiid or lyctid - same cure for both.
Now to convince LOML that a plastic-wrapped bowsaw will be a good feature for the freezer drawer...
Tenon too long?
Stuart Hough
>Might have been designed that way so there will be a pivot point for the tightening process. If you trim it so that it seats fully, you'll be putting pressure on the sharp-edged shoulder, which seems a good way to start a crack at that site. JMHO
Could be
>but the other tenon seats down to the shoulder, which I think was the intention.
Questions on refurbishing this bowsaw
>I started taking it apart tonight. The handle pins are 3/32", which I know because my 3/32" pin punch is getting trapped in the hole (need to dig down a bit in the hammer-and-punch drawer for the 1/16" punch). The previous owner, apparently having lost one pin, drove in what looks like a nail and peened it over on one end. Am I correct in thinking that a 3/32" drill bit would be good stock for a new pin?
What are the choices for the tensioning line, and where might one find them? The packing twine currently on it looks a bit frail.
For tensioning line, I've used Lee Valley's
Chuck Nickerson
>utility cord for the several bowsaws I've built (from the TFWW kits). The LV utility cord come in three strengths. I use the medium test (96#). The lightest test breaks, and the heaviest test looks too coarse to my eye on a 12" bowsaw.
Thanks for the suggestion
>My local hardware store carries similar braided line in multiple diameters. Have you found your line stretches and needs adjustment?
Re: Questions on refurbishing this bowsaw
>Use 1/4" diameter manila or hemp rope and end splice it together to form a continuous loop. Takes a little practice to get the length right, but the end results looks much better than a string with a knot.
Stephen
Re: Thanks for the suggestion
Chuck Nickerson
>I've probably tensioned it fewer than 50 times. In that time it might take one more turn to get it right; nothing significant.
Jack Guzman from Maine
Re: Could be
>I repaired a bowsaw in the colection of a local museum.It had a similar problem.I found the crossbar had been installed backwards.When I flipped it end for end,the tenons fit perfectly.Just a thought.---Jack
