adjuster repair
adjuster repair
adjuster repair
Bruce, a MN Galoot
>I have an old plane, a type 2 pre-lateral #7, obtained the old-fashioned way: I inherited it. There is a lot of slop in the adjuster, and whether the little knobs that engage the adjuster wheel are worn or always were loose, I don't know. The result is the same, that it takes a lot of turns of the wheel to move the blade.
Can this be fixed? Or do I just chalk it up to the character and charm of this olde beauty?
Thanks
Bruce in beautiful S. MN.
Re: adjuster repair
Chalk it up to character and charm
Dave Thompson
>Short of casting a new yoke with larger catches for the knob, I'm not sure what you can do for that contact point. Likely not the catch hole on the chip breaker which is another place slop on the depth adjustor occurs.
I'd enjoy it as is...
Dave
Re: adjuster repair
Re: adjuster repair
Raney
>Interesting - just this morning, Walt Q posted an 'old-timer' tip about wrapping waxed string or twine around the brass 'neck' of the adjuster to reduce slack. Haven't tried it, but it certainly sounds worth trying (and Walt's never led me astray before)...
Re: adjuster repair
Re: adjuster repair
Bruce, a MN Galoot
>I saw that, and once I figure it out I'll give it a try.
thanks.
bruce
Re: adjuster repair
Re: adjuster repair
Joe Rogers, Northern Virginia
>You may be able to wind one of these:
http://www.mcmaster.com/#catalog/115/3222/=2zfrc4
spiral locking retaining rings around the adjuster knob in the yoke channel to take up the slack. Note the retainer is thin and you need to measure the diameter of the root of the channel to find a match.
JR
Re: adjuster repair
Thanks, Joe
Bruce, a MN Galoot
>that will probably work. I'd never even heard of that gadget.
Bruce
Re: adjuster repair
Re: Thanks, Joe
>They are high performance piston pin retainers. Well, they are retainers that hot rodders use to retain piston pins. Very secure and can fit into a square cut bore. I guess you could stack them to add thickness if you need to.
JR
Re: adjuster repair
Re: Thanks, Joe
Bruce, a MN Galoot
>They'd probably stand up to the little force exerted by a depth adjuster, then, right? :-)
Bruce, also looking for the fix to a loose wrist pin in an old bike. (I know the fix - Honda doesn't make the parts anymore)
