The Ultimate Jack?
The Ultimate Jack?
The Ultimate Jack?
>A year ago I received a selection of timbers from my Galootclaus. A length of Ebony went to infill the Brese small smoother kit (and there is sufficient over to infill a St James Bay Thumb Plane kit). There is a block of Padauk. And there was this piece of Mesquite ...
I have been waiting to build a jack plane around a blade I bought last year. It is 2" wide and 5/16" thick D2. This is very abrasion resistant and could make a super jack plane for use on Australian wood.
This could be The Ultmate Jack!
The design is a mix of tradional vintage England with Malaysian influences. Mesquite body with Jarrah tote and wedge.
The razee body is 15 1/2" long, 2 3/4" wide, and 2" high at the mouth. This keep the centre of gravity low. The plane weighs 1.5 Kg (3.3 lbs).
The mouth is set wide for a thick shaving. The bevel has not yet been cambered. It will have a radius of 8".
The blade does not use a cap iron, and the wedge design keeps the mouth free ..
I should have a full tutorial on building the jack up on my website in a few days.
Re: The Ultimate Jack?
Re: The Ultimate Jack? *LINK*
>an iron 5/16" thick?
You really should have adapted a Hock or LN cap iron for such a spindly little iron.
Still, Rob Lee beat you to it years ago - see link.
As always, Derek, lovely work.
THIS is a cutting iron
I have that plane
>I love the thicker blade but the other day I had to sharpen it. My arm is still sore.
Tom
looks Great!
roninkokomo
Hank Knight
>That was my thought too. Derek and Todd O Cronkite are both hooked on those wuss little irons. I'll bet they flutter in the slightest little breeze. I think a chipbreaker is the least one could do to beef them up.
Seriously, Derek, that's a beautiful plane. I admire it as much as I do your long jointer. Post some photos of it in action on some of those Aussie hardwoods.
Nice job.
Hank
ThomD
>How does it look with your hand on it? The handle is set low in the razee, but the swell above the thumb looks really high. I made a similar plane a few years back and designed the handle etc..., but it came out over an inch too high. I have a new pattern though I haven't found the right piece of wood for it yet. Sorry to be brusk, but I am supposed to be driving 1000 miles to New Brunswick today!
>Hi Thom
Fair points.
The tote has the same dimensions as the one I used on my jointer (which is comfortable). It is a scaled up Stanley - thicker and longer (I have a broad hand) ... designed for a four finger grip rather than three finger grip. The direction of effort is down the blade. I will post a picture when I get the tutorial done.
Of course I will only know for certain once it is used, which will have to wait until the weekend. It should be a workout as I am about to start a tallboy.
Yes it is!
>Hi Scott
I have the pictorial almost complete. I hope to put it on my website tomorrow. Many pics. Here are a few ..
The 5/16" thick blade after grinding and honing ..
As it looks in the mouth with its 8" camber ..
The blade is very sharp and the plane cuts effortly.
I tried it on Pine first. Well that was no test at all. It felt like it was not there at all ..
And then in hard Jarrah. The plane just seems to zip through the wood.
Glad to see it!
Scott Burr in Ben Lomond CA
>Looks like it's gonna be a winner. Can you tell me how much camber you put on the blade?
It turned out very nice, like most everything you make. ;^)
