Re: Input needed *LINK*
wilbur
>Hi Wiley,
This is a roundabout way of answering your question. I found with my old temporary poplar beam on sawhorses workbench that you can completely immobilize even a light workbench by figuring out ways to brace it against a solid object, like a wall. (See the link below.)
What I'm trying to say is that there are other ways besides sheer mass to keep a workbench in place.
By the way, my own little moment of workbench fame came when Chris Schwarz told me when I met him that he often refers to that post when people ask him the "How do I build a workbench without a workbench?" question.
As far as the LV cast iron legs you're looking at, the only issue I can think of is that the anchoring point of the benchtop to the legs is going to be relatively central, which might lead to more issues of racking the top if you have your plane stop towards the end of the benchtop, or are pounding on the end of the bench top. With a 36" long top, there's only going to be a 10" overhang along the length of your bench with these legs, however, so it might not be an issue.
Lee Valley also sells the cast iron legs from their regular workbench -- try this link:
http://www.leevalley.com/wood/page.aspx?c=2&p=40575&cat=1,41637
Those legs seem more suitable for what you want than the carver's bench legs.
The only other way to get a small bench quickly that I can think of off the top of my head is to make your 20" x 36" top, with an assembly to clamp it in a Workmate-type bench, which might give you the same issue with the central mount point, depending on how big the Workmate model is.
A scrap piece of 1x4 is as good as a 400 lb bench!
