Left-bevel hatchet/axe
Chris F
>Hi all.
I was doing some reading online, and found an article that described dimensioning lumber to rough size using a hatchet. I think I saw St. Roy do this in a show at one point as well.
The hatchet I saw being used had a single-beveled blade...the flat side was towards the work, with the bevel towards the waste side. This seems like something I really need to start doing, as doing this with a scrub plane (or worse) a bench plane is taking me forever.
The trick is that I'm left-handed, so I'd need a hatchet with the bevel on the OTHER side. I know nothing about axes and hatchets, aside from these articles I read. Does anybody know if such a beast even exists?
TIA for any feedback!
Chris
Re: Left-bevel hatchet/axe
Mike Jurnigan in Suffolk, VA
>Just put the handle in from the other end of the hatchet head. Left hand broad hatchet!
Mike in Suffolk
R Payne
>Some are convertable from right to left just as described above. Some are just right or left handed. A real quick search found a convertable one made by Vaughan available at Highland Woodworking.
ron
ThomD
>Goog advise on reversing it if it allows it.
There are something like 7 haftings and bevel combos available from Gransford, for their dedicated hewing clients. Some are double bevel, others are single bevel offset inside while, others are single bevel offset outside. You can hew effectively with either. What you need to get your mind around is the purpose (along with preferences). In general a hewing axe is a finishing device, one does not hew then plane since the hewn surface is sufficient (on beams). So you may wish to consider whether what you are attempting is nearer a finishing cut, for which the single bevel with bevel to waste is the normal choice, or whether you are blowing out wood, in which case the single bebel inside, or double bevel is the normal choice.
The axe is used to cut through the wood so that it takes a curved cut, so there is little apparent tearing of the wood fibers. There is always a little blade offset to allow the axe to take a curved cut like a jack plane or a scrub plane. I find it easier to do the roughing with a more or less standard axe or hatchet. I either hold the work on the block at the bevel angle of the axe, or I hold it somewhat straight and rotate the axe in my hand while allowing it to fall along the line of the bevel angle. But there are specialty axes that hold double or single bit axes with the bevel to the inside.
Chris F
>I took a look at that Vaughan hatchet....the description for it says you have to make a new handle to convert it to left-handed use. I would imagine that probably makes it the same as every other single-beveled hatchet on the market. :)
Chris F
>Thanks for the replies. Basically, I'm just looking for something that will allow me to take a piece of wood (more often than not 4/4 material) and get it close to its final width fairly quickly. I keep running into situations where a board may be an inch or so too wide, an I end wasting my time either ripping it with a saw, or planing it down an inch (I don't own a drawknife). Once I saw this task done quickly with a single-bevel hatchet, it seemed to me that it would be a REALLY good idea to give this a try.
