Tuning up Wood Rebate, T&G and Plough Planes------
Bert Bleckwenn------WebKitFormBoundary3cBabUYv+3+c
>I'm looking for any guidance on do's & don'ts for fine tuning a set of wooden planes. I have a basic set of six wooden planes (1" rebate, T&G set, and three different size plough planes with nickers and depth adjustments) that were given to me by my father-in-law who had purchased them for me from an old master house carpenter in Iowa. They appear to be in pretty good condition, but definitely used and were owned by at least 2-3 owners based on the multiple embossed names besides the maker's name... a little rust and grime as I think they haven't been used for the last 10-20 years, but just cosmetic.
Questions I have are:
1) The blades are sharpened with a couple of them being slightly rounded rather than flat or concave... I'm proceeding to regrind the rebate plane iron with a Tormek and hone with waterstones... Any reason why they might have been slightly rounded? Seems like it would be difficult to re-sharpen/hone.
2) Is there a standard angle used on most wooden planes when the blade is skewed such as my rebate plane? I've resharpened the rebate plane iron, but appear to be off a degree or so as it cuts slightly thicker to one side even though I thought I reground it to the same angle. I can see that the angle is slightly off by sighting down the plane. I Would like to make a skewed block as a jig to set the angle and pitch so sharpening and honing is repeatable, but was wondering if there was a "standard" or did each plane maker have their own standard and varied between planemakers?
3) One of the plough planes has a very small crack emminating from where the depth gauge foot is located on the bottom towards the mouth. The crack is pretty tight so don't think I can get any yellow glue into it, but how about some thin cyranoacrylic glue? Or is this a no-no? Any suggestions?
4) Should I apply anything to the wood such as linseed oil, or best to just wipe with a damp cloth or something?
5) What type of hammer should I use for adjusting the plane... brass, wood, rounded head?
6) How should I protect the blades when storing them besides retracting the blade below the surface? On the rebate plane, the corners stick out slightly even when retracted as I already clipped a finger... I was think about buying a short length of large flexible clear hose at a big box store, slit it and slide it over the bottom of the plan similar to some of the plastic protecters that come with saws covering the teeth.
Any guidance will be appreciated.
------WebKitFormBoundary3cBabUYv+3+c4Mov
Re: Tuning up Wood Rebate, T&G and Plough Planes------
Norb Schmidt - Cumming, GA
>I'm no expert - but I am really enjoying getting to know the good wooden planes and I'll just share my thoughts. Remember, they're worth what you paid for them, so confirmation might be a good bet.
1) No - The blade should cut straight across (not sure of what you mean by concave?) You want square rabbets. This is likely sharpening error.
2) Grind angle would depend on the bedding angle. Assuming you are no greater than 50 degrees (bed angle) you could use 30, thus preserving edge life. You NEED at least 12.5 degrees of clearance angle, so act accordingly. Secondly, to get the correct angle on a skewed rebate, color the blade with dykem, set the protruding blade, then scribe the sole of the plane. Now you have the correct angle for grinding/honing. (you might want to square up the sole using sandpaper and a straight surface).
3) I'd try the glue. It's cracked now, what is the glue going to hurt? Especially if the crack is due to wedge pressure - it will only get worse.
4) Clark & Williams only uses Minwax Antique Oil finish. It does not expand when it dries, so it won't check your planes. Good enough for Larry, its good enough for me.....
5) I use a small brass hammer on the blade, and have moved to a small rubber dead blow for the wedge. On small planes, you will have to set the blade on the way in - you don't typically get enough action retracting the blade by rapping the back or the toe like a bench plane.
6) Use prudent judgement on protection - but for me, taking on and off a hose would get old in a hurry.
That's all I got.
Hi Bert...
Scott Burr in Ben Lomond CA
>Let's see here.
1. Flat
2. Start with 25 deg for soft woods 30 for hard.
3. Super glue, runny
4. Clean with mineral spirits, with a light to increasing hand. I like 00-000 steel wool depending on the grime. Scotch Brite pads work well also
5. Why a plane adjusting hammer silly!
6. None needed IMHO. Just be carefull.
7. Show us some before and after pics!
Cheers!
