Re-use of worn plane irons
Jay Samuels
>NOT due to any design failure, I need to slit off about 3 feet of molding that I put up that protrudes about 3/8" past where is should. I figured that the easiest way to do this would be to create a custom slitter to ride along the adjacent board, which would need a good-sized single bevel blade, like a marking knife. I took an old Stanley 2" plane iron that had been sharpened about down to the slot, cut off half at a 45 degree angle with a rotary tool, and proceeded to grind a single bevel on each edge. I had always thought that the top parts of the plane irons were some lesser quality of steel, but based on the spark pattern and the effort necessary to grind the bevels, this seems like nice high carbon steel. It took a nice edge. I don't know that edge-holding should be much of an issue for a slitter. Now I just need to complete the body. Has anyone else recycled the tops of plane irons for custom applications? If so, having tried this, I would be interested to hear.
