Re: Second thought regarding Mark Grable
Mark Grable
>Well, yes, I find this computer (which I borrow) to be less tractable than saws. Why did they mix-up the letters on the keyboard anyway? Could'nt they make at least the keys out of wood? As for Gordon's saws, I really enjoyed working on them, the blacksmithing work very sweet. I hope I can do as well when I get to that phase. Dozuki are very different from other types of saws. The back is mild steel, and formed in such a way that it springs tight around the blade. Not like folded paper, creased to lay flat - more like a string bean which has some open space in the middle. The very top of the blade nestles in bottom of this channel, if the teeth are pointing up, and the sides of the blade are held at the top of channel. This narrow elipse cross section back is stiffer than a back with parralell flat sides. The back and blade become a unit. If the saw rattles when tapped on the side, it will rattle when cutting (or pulling, as is said half-way-round-the-world). Not good.
Because the mild steel back has more stiffness than spring, the blade has to be of uniform thickness along the back where its held. Gordon's dozuki's back came right off, and while we didn't use feeler gages or micrometers in Miki Shi to put backs on new saws, I use them to re-set loose backs, unless the back was formed completely flat (hopeless). The mike showed the front 0.013 in. for about an in. long, then 0.009 in. for an in. and a half, then 0.012 for the rest up to the taper at the neck. So I used a file to reduce the thickness at the front to 0.009, relaxed and straightened the blade, and did what I could with the back, though it had been flattened to a degree. If I had an unlimited supply of new backs, I would have put a new one on, but I may not be able to get anymore, and have to figure out how to make them. It can't be that hard, Yataiki bought his - somewhere. The other problems were the commonplace not-quite-flat/straight, one side set more than the other, and some teeth not quite completely filed down to the jointed level: flat on top. Getting the cutting edges (points) to all be the same hight is very difficult, and machines are better at it than I am, but perfection is not required. A bit low is much better than leaving a jointed flat top, but when I put the saw back in the vice after pulling it through a piece of wood to get the loose burrs and fileings off, I useually find some teeth to finish off. It takes more time to sneak up on 'em like this, but I have only once had ten saws a day to do on two consecutive days. (20) Then there were none for a week, then a couple. To be really skilled you need to do more than ten a day. Specialising in one or two brands also helps, and avoiding pitted saws. Maybe someday.
