DIY infill: Exploded view *LINK*
Craig D
>The stainless steel infill kit I got from Andy Lincoln (via a Benefit Auction) is basically done. Just need to finish finishing the tote.
Removes wood well (yes, I know, the proof is in the pictures, I'll get there).
Some particulars: Same size as a #4, weighs a bit more (maybe 1#, forgot to write down the numbers), 55 degrees, four finger tote, 1/4" iron, movable frog, jatoba infills (infused with BLO, then varnished).
Craig
Blog
Re: DIY infill: Exploded view *LINK*
Right nice
>I'm glad you knocked me out of contention on the bidding - you did a much finer job than I would have (and a lot sooner).
Whew
>Nice work. I see I'm going to need some kind of milling machine for this job. I haven't been following your updates, Craig. Are threaded inserts standard fare for attaching the wood to the body?
Re: Whew
Craig D
>Ellis wrote:
>Nice work.
Thanks!
I have a mill so I tend to use it if at all possible. But this project could be done without one; it was vital for shaping the lever cap and frog but if you keep the Norris lever cap shape and have a fixed mouth, a drill press will suffice. The lathe may have been more important (for center drilling pins, threading and making the cap screw).
No, I haven't seen them although I used them on my last infill smoother, from the sole. In this case, what look like inserts are actually stainless 3/8" rods that extend though the bun. The rods space the sides and provide rigidity to the shell. The bun "floats" on the rods, it isn't fixed to the shell. Other infills use hollow [brass or steel] rods in infills and pein a pin though the rod. I got my idea from Rob Brese's planes, he uses aluminum rods, peins over the screw head and files them flush so you don't see them. Very pretty. In all cases, the idea is to prevent wood movement from moving the sides of the shell (for wood shrinkage anyway).
Craig
Re: Whew
Craig D
>This photo shows the bun though rods.
Very nice job. My
Victor Parisian
>round tuit list just got longer...
Victor - still at work on Friday afternoon
Aha
>So you drill and tap the rods for those screws. And, you make the bun a little narrower than the width of the body opening and let the ends of the rods form shoulders on the inside of the body sides. That leaves the small matter of getting all the holes to line up. Can you discuss the procedure?
Re: Aha *LINK*
Craig D
>Ellis writes:
Correct. The rods are exactly the width of the inside of the shell; I used them to hold the sides parallel during assembly. The bun is a tiny bit narrower, just enough to be a slip fit in the shell. I'm hoping the bun won't swell, it is humid time here in Oregon and I infused it with oil (put it in a vacuum and then let it suck up oil) with the hope that would retard movement.
Sure. After the shell was assembled, I trimmed the bum to width and set it it in the shell. I outlined the screw holes on the bun (with a pencil), then used a Veritas optical center punch to mark just above center (I love that punch, it works really well). Then clamped the bun in a vice and used a 3/8" forstner bit in the drill press to drill in one pass. Don't drill from each side, the holes won't line up and the rod won't fit (speaking from experience). You'll probably get some blow out at the exit but it is hidden by the shell. Now, since you drilled on the high side, sand the bottom of the bun until you can just get a screw into the rod, which will force the bun to the bottom of the shell (via the counter sunk screw hole). If the rod spins, you have several options: Add a shaving and slide the rod over it. Wait until you finish, the finish film will reduce the hole diameter. Drill a hold from the bottom, though the rod and add a pin. The finish works for me and a screw driver on each side works for assembly. Don't glue the rod for the same reason you don't glue a breadboard end (or just glue one end before you push it home). I left the front of the bun long and trimmed it later in case the rods weren't perpendicular.
My method is a lot of extra work as I was being a bit anal. You could just put the rods in approximately the right place, clamp the bun to the shell and then drill the rods. You will need to pin the rods to keep them from spinning. If you go this route, read Jameel's blog entry (or read it anyway, it is excellent).
Craig
Brese 875 Smoother--Pinning the Infills
And a shaving too! Well done!
Scott Burr sweating under the redwwod
Wow, I was afraid of that
>Knowing me, I would have probably just fit the bun perfectly then drilled a pilot hole through the shell and the bun, following up with a 3/8" bit to drill out the rod holes and a countersink to prep the shell for screws. Then I'd have drilled and tapped the ends of the rods and, if I was concerned about the wood expanding, disc-sanded the side(s) of the bun a touch to create the necessary clearance.
Your method is all custom fitting, but it gives you better control over the whole process, at the cost of more work.
How much expansion do the Sauers and Andersons of the world allow for, I wonder?
Thanks for the explanation, Craig. That plane is looking really nice.
Re: Wow, I was afraid of that *LINK*
Craig D
>Ellis writes:
I think that would work just fine, the bigger drill (if it is a twist drill) will follow the pilot hole. I used a forstner bit because it drills a more accurate hole. However, remember that in this case, Andy's plane kit already has holes drilled in the shell.
Well, my methods of work are designed to allow me room to fix screw ups, which I make a lot of. This plane is very much a prototype (for me) so it is custom in that regard.
Good question. As far as I can tell, modern makers allow for wood shrinkage. I'm assuming that aesthetics require no gaps between the wood and metal on a new plane (it did for me). A tropical wood doesn't move much so it is very good for this application. Karl Holtey talks about this issue in one of his blog entries.
BTW, the stainless peins nicely. You may have noticed that the two rear pin holes are missing - they were filled and piened.
Craig
Holtey: A Window into my workshop 1
