Warning: Electrons Involved
>Not destroying them but creating them. I have had this in mind for a while and after acquiring some thin zinc sheet and doing a preliminary test, which worked, I continued. Alternating layers of copper, zinc and a spacer such as paper, cloth or felt and either salt water or mild acid.
There is some woodworking involved but it is minor, just holding the pile in place. It is based on the design of Alessandro Volta from about 1800, for the first battery (there may have been earlier ones).
Volta Pile 2
I will saturate the white wool felt with supersaturated solution of salt when I am ready to turn it on.
Then I will need something for it to do.
Stephen
Re: Warning: Electrons Involved
How much you think it will generate?
Patrick Gibbons, Katy, TX
not creating but releasing them, neat!
Bill Tindall, E.TN
>The electrons are already there in the zinc anxious to get out and do some work.
I would like to make one. Would you provide some detail on assembly? You say the battery was constructed from sheets but it looks like a wrapped thick wire. Is it one cell of several?
Re: How much you think it will generate?
Victor Parisian
>Patrick, if my memory serves me right about 1.5 volts per layer. How many layers? Can't tell from the picture. looks like several though.
Amps? That should be a function of the total surface area of the zinc (don't know, just a hunch).
Victor - watching the temp rise above a hundred again today.
>There are 30 sets of copper, zinc and wool felt like in the original pile. They measure 1 1/2 inches in diameter. Should be a decent battery.
Stephen
Re: not creating but releasing them, neat!
>Bill,
You are correct, I was just thinking of potential. It is as close as I can come to the original size, the discs may have been larger. It is some sheet copper, of a thinner gauge than the sheet zinc. I got it from Van Dyke Restorers they sell it in various sizes.
Because of the work it took to make this one, it will be the only one I will ever make. I am however going to make a wet cell battery for the Telegraph Office at the Historic Park where I work. That one will be a lot easier.
Stephen
amps
Bill Tindall, E.TN
>Amps are limited by the internal resistance of the battery which is a function of the electrolyte and insulating spaces. This is why batteries with BIG "cold cranking power" are not such a good idea. They get it by using very thin spacers that fail easier and internally short the battery.
I doubt this kind of battery generates 1.5 volts per cell. It is probably a smaller fraction of that amount.
Re: amps
>Here is a test I did when I first got the zinc. It is 3 layers that measure 1 inch square.
voltaic pile prototype
I had to borrow the modern volt meter from a friend.
Stephen
Here I was just going to rib you a bit
John in NM
>about the volt meter, then I scrolled down below the pic!
Move over Rube Goldberg.
Victor Parisian
>That is one fancy set up there.
Ya, I know there really isn't a neat way to hold those round probes, make decent contact and snap a picture.
Still waiting on results of Voltage for the whole rig.
We saw banks of glass batteries at a frontier ranch museum in Guadalupe Mountains National Park. I don't remember if they were attached to a wind generator/turbine or not. I'm sure they must have been. Likely used for low voltage lighting and powering the radio. They were in the side building that was the one-room ranch school.
Victor
