LN fishtail chisels *LINK*
Pam Niedermayer, Austin, TX
>You guys may want to check out the new(ish fishtail chisels from LN, very cool, about half as expensive as the Japanese versions, maybe a bit less than half (probably shouldn't say this out loud, don't want to encourage anyone to raise prices), and made from O1 tool steel. I think LN just saved me a bunch of dollars, although I probably won't buy any until the end of the year, still have the custom 9 mm bachi nomi that does the job for me; but these are just too cool to pass up.
Pam
LN fishtail chisels
Re: LN fishtail chisels *LINK*
cost
paul womack
Given that these have a re-sharpenable blade length of about 1/2", I think you could save even more by buying (or grinding - save even more!) a pair of skews!
BugBear
Also look at the Blue Spruce fishtails
>Blue Spruce sell a set of fishtails that I prefer to the LN. The handles are longer (the reason I bought their dovetail chisels rather than the LN). There is more usable steel. They are the same price.
I have a pair. I must admit that I would not have bought them (as I had a set I made myself) but was offered them at a sale. Beautifully balanced.
BS ($75):
LN ($75):
and one of yours truly (beyond mere $):
OK, compared to the Japanese version *LINK*
>I'd save a lot of money. Granted, Paul, my bachi nomi is probably a better long term value, and Derek, I like the looks of the Blue Spruce; but the Tasai are so compelling, I really want a couple of them, and the LN are so close. I doubt they'd wear out in my lifetime, any of them.
Pam
Tasai dovetail chisels
Re: Also look at the Blue Spruce fishtails
Jim Shaver - Oakville, Ont, Canada
>I too have a Blue Spruce, like you said I like the longer length of the tool.
Take care,
Jim
Kevin Adams
>Well, I, too, have the BS and also like them a lot. However, I got to play with the L-N's last week while I was up at their shop and they are wonderful tools. You can get them with a longer paring handle, which would be my choice. Personally, I prefer these tools in O-1 vs. A2 since they are basically paring chisels and can carry a lower angle with the O-1.
BTW, I had a gift certificate burning a hole in my pocket, so I just had to walk away with one of the new T&G planes...very sweet and I have a project in the works where they will be well utilized!
Kevin
>Fun. There's something about the shape of the LN and Tasai that makes them look more weighted, kind of like the Condor (supersonic airplane), therefore more purpose built. I'm sure I'll buy at least one to try. I don't buy A2.
Pam
Condor?
Scott Burr in Ben Lomond, CA
>Or did you mean Concord?
I like grape juice...
Tips?
Tony - Memphis
>So, can you give us some info on how you made yours? I love my fosh tail carving gouges. I can see using some regular chisels in that configuration.
Thanks,
Tony
Re: Condor?
Victor Parisian
>Scott,
Would that be fermented "grape juice"?
Curious minds etc
Victor
Re: Tips?
>Hi Tony
This is a very easy item to make if you are simply reshaping on old chisel blade, as I did (rusty old Witherby in my case).
I calculated the dovetail angle I wanted, marked it on the steel, then ground the waste away - use either a grinder wheel or a belt sander.
If you work carefully and quench the steel frequently then you may get away without altering the temper. However I would not be too concerned about this. See below.
A quick refresher on heat treating: Once you have shaped the fishtail, heat the blade until red hot (I use a couple of Mapp bottles together - sometimes three at the same time to generate enough heat), immediately quench in water. You should have a hardened blade that a file will skate over. Clean the steel.
Now temper the blade in the oven. I set it for 275 C and expect that this will take about 30 minutes. Check the colour of the steel frequently. You do not want it to go beyond a straw yellow. Remove it and quench again.
You will need to lap the back of the blade, but it is small and narrow and so this will not take long. Start at 80 grit otherwise it will take forever.
Hope this is what you were looking for.
Hmmm Mad Dog 20-20...
>Or would that be Night Train?
No, I meant the flying vulture.
AFAIK There are no supersonic vultures
Re: AFAIK There are no supersonic vultures
>I can't begin to speak of our lack of knowledge, Scott. :) Think French supersonic plane, called the Concorde or Condor or whatever thrilled flyers everywhere except those in the flight path east of DC.
Pam
Damn, no supersonic vultuers....
>Guess Bugs Bunny will sleep better tonight. I hope MJ does.
I'd never heard that nickname - cute *LINK*
>though I always thought the Concorde looked more like one of the spies in Mad Magazine's "Spy vs. Spy" series.
For those not familiar with "Spy vs. Spy"
name?
paul womack
>Having grown up in the era when the UK and France blew their budget (and how!) on Concorde, I'm surprised at this name.
I've never heard Concorde called any thing other than Concorde, and a brief check shows no uses (other than our own Pam) for "Condor" or "Flying Vulture" anywhere.
Pam - it's hard to tell from your super short posts - is this a name you've heard, or a newly coined witticism for this board?
BugBear
Re: name?
>Oh, I was just thinking of the angle of wind attack of the head of the condor, a magnificently named vulture, and how the Tasai and LN dovetail chisels seem so like it; so then I decided to make a play, given they look very much like the Concorde, too, I added the supersonic description. And now that you know all my tricks.... :)
Pam
Well, with some creativity & a big rubber band...
James Watriss
Thanks!
Tony - Memphis
>I may try that. I remember when I was first starting out, I was interested in some skew chisels for making tombstone panels. The best suggestion I got was to go to Home Depot and buy a set of Bucks and grind them into skews. I'll have to keep my out out for some cheapies to "operate on."
Tony
Can somebody send Tony a cheap /broken chisel?
Victor Parisian
>My kids are grown now, so I no longer have any with broken tips that would fill the need.
Tony, just report back on the results.
Victor
