Coffin Smoother
Coffin Smoother
Paul Kramer
Coffin Smoother
Paul Kramer
>All,
My oldest daughter recently returned from a trip to Spain and while in Barcelona she picked up a gift for her Dad (Me). She knows precious little of woodworking -- not because of a lack of trying on my part. Anyway she recognized this tool as one she's seen in my magazines and bought it for me. I think it was cobbled together from parts.
There are some issues there is a split in one of the sides but I think a repair is holding okay. The wedge is also broken but may not be a big issue. The blade is 5/32" thick but there is very little usable blade left. The blade is marked, "Peugeot Freres -- A Garantie" obviously French. The blade is bedded at 55 degrees. The mouth is way too big for a smoother. The body has a cut-out for the screw for a chip breaker but there wasn't one and I'm not sure how one would work with the wedge.
After a quick going over followed by a quick and dirty sharpening it worked amazingly well on some pine/spruce.
Any suggestions on what to do to optimize this little beauty?
Thanks in advance,
Paul
Re: Coffin Smoother
Re: Coffin Smoother
Wiley Horne--So. Calif.
>Paul,
That's a fine daughter you raised. I would suggest just use it the way she brought it to you. There'll be uses for it. The main fun will be to see how much you can get out of this plane, with blade sharpness, more sharpness, and a little camber. High angle and sharp can do a lot for you.
The person who had this plane before you got plenty of use out of it, judging from the iron.
Wiley
Re: Coffin Smoother
Re: Coffin Smoother
>Hi Paul
Congrats on raising a daughter who will buy you planes!
I would plane this plane in a prominent position in the workshop, and then leave it there. It is for gazing at, not for using.
Too many problems: it is designed to work with a cap iron. I am not sure if the wedge will stay in firmly enough without one. The blade is very worn and it may be into the softer steel. So edge holding may be a problem. The mouth is too large to use it other than as a scrub, and I wonder if the blade can take this. You could close up the mouth .. but then you need to deal with the other parts.
If you want to use it as is, I would add a 15 degree backbevel, which should take the cutting angle to 60 degrees. At this angle the mouth size plays much less importance. You could use it as a smoother for interlinked grain (assuming the wedge secures the blade sufficiently).
Personally I would just give it place of honour in the workshop, and gaze at it fondly every now-and-then.
Re: Coffin Smoother
Paul Kramer
Re: Coffin Smoother
Paul Kramer
>Derek,
It's already at 55 degrees. Would the extra five do any good? The wedge holds the blade very securely and the blade seems to take an edge well. Thanks for the sage advice.
Paul
Re: Coffin Smoother
Re: Coffin Smoother
>Hi Paul
That is a nice surprise - that the bed is 55 degrees. Even 55 degrees will reduce the dependence on the mouth. Use it as is and if it works OK then just keep it as is. If not perfectly OK, then add a micro backbevel of 5 degrees ("micro" means you create it with a stroke or two, which then can be removed easily as you hone the primary bevel).
