Re: LV Scraper Plane Tips?
Wiley Horne--So. Calif.
>Hi Tony,
Which of the LV scraper planes do you have, the small or the regular large size?
The thing i have experienced is that if I'm not getting the right shavings, it's because of an angle mismatch, and usually that I've put too tight of a curl on the hook, so that the blade wants to work at a lower angle than the plane allows (or that I've got the plane set for).
So I agree with Alan and Thom's approach about getting the angle right first. Which is why it matters if you have the small or large LV scraper--the small has a fixed bed angle. If you have the small plane, just take the blade out of the plane and see what angle it wants to cut at, and if it's very far off 20 degrees from vertical (the plane's bed angle) then that's the answer.
Wiley
