Sanford Uni-Ball Power Tank Pens
Alan DuBoff
>I have to say, it is not often you run across a product that just works so good for a given task that you become very fond of using them.
What is unique about the Power Tank is that the pen is pressurized and you can mark at any angle. Fisher sold a space pen that some folks may remember, you can still get those in some places also. Those were used to go to the moon during the 60s...not to digress, you can still get those pens as well, but these Power Tank pens are uni-ball pens, and as such the ink does flow nicely.
In the U.S. they only seem to sell the 1.0mm ball (bold), which produces a .4mm line. However, in Japan they have ones that are .7mm ball, and they are a fine point, I just got some of these fine tip pens, turns out the Japanese use them for writing Kanji as the tip is small and the ink doesn't blot on the characters. At least how I understand it. You can buy these online. Easier to find the 1.0mm ball, they sell those in the U.S. All come in Black, Blue and Red.
Not only do they mark in all directions, but they will mark on wet wood also. This is handy if your working in the rain, or if you mark something that is sitting in the rain.
The red is nice in case you make a layout mistake...the color stands out from the original marking.
Anyway, I typically use a ball point pen for marking out dovetails on furniture, and mortises and such, but will be using these now.
It must be a Power Tank to be pressurized.
