question on "antique" hardware installation
Bill Tindall, E.TN
>I have never installed hardware with these spreader pins before. Any secret to installation, especially getting the handle tight against the trunk so it isn't loose after installation?
Re: question on "antique" hardware installation
Chuck Nickerson
>My guess (please note this is a guess) is good instructions for using clinch nails would be helpful. Tremont Nails still sells them, Chris Schwartz has written about them, and I suspect Stephen Sheperd has something to offer on this topic.
>Bill,
The cotter pin shaped snipe is put through a slot, some use a hole, but that can allow water in the chest/cabinet. They are then bent or clinched over to hold them in place.
I always bend a bit of the end of the snipe over to form a point that will engage the wood like a staple when the snipe is clinched over. You can also use nippers to put a bit of a barb on the snipe to further enhance its hold when it is driven into the wood.
Stephen
Re: question on "antique" hardware installation *LINK*
Wiley Horne--So. Calif.
>Bill,
Attached is a drawing by Horton Brasses that illustrates their recommended method. They show clinching like Stephen recommends.
Wiley
Horton Brasses on cotter pin fitting
