DIY Infill, the frog part II *LINK*
Craig D
>A little more traction on the frog for the stainless steel infill. Basically an aluminum mouth block that slides back and forth on studs brazed to the sole, like a bedrock.
As this was both brazed and peined, I can say this alloy does both quite well. Also, in case anyone is wondering, the moveable frog means that the iron gets no support from the sole (when you look at the mouth block on infills, it is usually filed as an extension of the sole). But the 30 degree bevel on the 1/4" iron means the iron wouldn't touch the 3/16" sole (exaggerated in the photo).
There are three blog entries on how I attached the studs.
Craig
My blog
Re: DIY Infill, the frog part II *LINK*
Excellent work!
Scott Burr in Ben Lomond, CA
>If I do say so myself. Nice blog as well. I look forward to see it completed! (yea, that means keep sharing your progress).
Re: Excellent work!
Craig D
Thanks! I'm also really looking forward to completing this, it is taking it's own sweet time. This is my third movable frog (one Bailey style & one infill) and all three are different, which means a lot of head scratching and false starts.
