Rockwell stair gauge
David Miller from Iowa
>Just picked this up at an auction - cast iron, Rockwell Industries Pittsburgh and 50#.
Questions:
Does this look complete?
Is this worth anything? - nothing similar sold on eBay recently
I acknowledge this may be associated with a power router, but this item has no cord so I'm claiming plausible deniabilty for posting here on the hand tool board - I don't know those people on the other side.
Re: Rockwell stair gauge
>Actually, I think it's a stair jig, rather than gauge - used to cut the tread and riser mortises in the stringer for closed-stringer stairs (think of Victorian and other formal houses). Porter-Cable continued to sell it or something very similar for some time after they took the P-C name back from Rockwell.
It's used with a Norm-type router, guide collar, and straight bit. You would fuss around to get the settings right and then clamp it to the stringer, do your routing, step it up to the next tread location, and repeat until done. Electrons die in the process.
I presume it's designed to work with either side up, since you might often be cutting identical but mirror image stringers.
As to whether it's complete, and what it's worth, I haven't the foggiest idea. If there's a local shop that specializes in stairs, you might be able to find someone who can look at it and tell you the former.
The answer to the latter question is, of course, "whatever someone will pay for it." It's a specialized enough tool that I'd be dubious about its value on the open market, but maybe the workers in specialty shops spend their lunch hours wondering if some innocent's going to walk through the door with one to sell; just don't know.
