Shooting Board
Hank Knight
>Several people here and over on WoodNet inquired about my shooting board when I posted photos of my new Brese Shooting Board Plane. I took some photos of it today and thought I'd post them with a little explanation.
There's nothing special about the shooting board. The configuration is pretty standard. I built a base with a fixed fence at 90 degrees to the edge. I glued plastic laminate to the plane bed so the plane would slide easy. I tapped the fixed fence to accept brass machine screws to attach a replaceable fence. They get damaged over time and it's handy to he able to feed a new edge to the plane as it gets chewed up and to replace it when it gets totally trashed. I used pretty large machine screws so the threads into the maple fixed fence would be stout enough to serve over time. I also built a 45 Degree miter fence with adjustable/replaceable fence faces. It is attached with a shoulder screw (bolt? not sure of the terminology) that screws into a T Nut let into the bottom of the shooting board. The back edge of the miter fence registers against the fixed fence. Here is a photo of the components:
The basic board is 1/2"baltic birch ply. There is a center section of 1/2" ply that creates the trim edge for the plane. I didn't like the idea of the plane riding against the plywood edge, so I glued a maple edge strip for the plane to cut aginst. I went ahead and wrapped the whole thing in maple just because I thought it looked better than the plywood edge. The fixed fence is maple and the replaceable fence faces are goncalo alves my friend Ray Binnicker gave me. It's really tough stuff and should last a while. Here are some photos:
Rear view of the fixed fence with the replaceable fence attached:
Front view:
Miter fence:
Maple edge treatment:
One of these days I'll make a donkey's ear, but I haven't needed it yet.
Hank
