Homemade Stains...
Homemade Stains...
Homemade Stains...
John L. Blue
>like rusty nails and water for a rust stain, name your favorite stain.
Re: Homemade Stains...
Alkanet Root and Linseed Oil
Greg B�tit, Crown Point, NY
>Crushed walnut or butternut husks in water.
pigments
Bill Tindall, E.TN
>I grind mineral pigments, for example burnt umber, in linseed oil. Diluted a bit with solvent they make a light fast pigmented stain that I use on cherry and walnut. These stains have the advantage that they never change color with time because they are ground minerals, typically oxides of iron and manganese.
An accidental dye
Wiley Horne--So. Calif.
>Some years ago, I was working with padauk (Andaman islands, Pterocarpus dalbergioides) to make a 'tree' to hold necklaces for my wife. The wood was quite red after planing. To keep the bright color, I finished with shellac right over the bare wood.
What a mess. The second the alcohol hit this wood, there was bright red dye everywhere. I recall it was a job to get it off my hands, and I used alcohol to elute it off my fingers (so as not scare children or my wife).
Padauk is sometimes referred to as 'vermilion wood', vermilion being a red/orange. I suspect the color is fugitive, because the finished object I made oxidized down from the red/orange to a reddish brown. Also, anything dyed with padauk would need to be have the dye sealed with something other than shellac.
But you can sure make a bright vermilion dye by planing off a bunch of padauk shavings, and add alcohol. Instant color.
Wiley
Black
>OK not quite homemade.
In addition to the usual ebonizing strategies, yesterday I was experimenting with adding Indian Ink (I'll call it that - it was actually the ink one uses with stamp pads) on Jarrah. To date I have struggled to stain Jarrah with traditional dyes. All barely penetrate, and then leave a streaky finish. The ink is very good. Extremely close to Ebony (only the more open grain of Jarrah gives it away).
Re: Black by Boggs?
ThomD
>Rusty nails are going to give you black on high tanin woods. But I have these 5 gallon drums of oil that somehow got rusty and the end result was a veny nice brownish darkening of maple on my bench. A couple of clients have come into my shop and looked at my bench and said "I want that". I don't like stains generally but it just turned out that way. Not sure what I will do whent he drums are gone.
Speaking of black, what was the Boggs formula recently published in one of the mags. I just assumed he was using the iron water approach, but apparently not.
Yep, me too...
Scott Burr in Ben Lomond, CA
>Try the waterproof one as well. My favorite is Higgins, you get it an art store. Also reduced coffee is fun as well. If your looking for green try steaming some Artichokes, them reduce the cooking water.
Re: Yep, me too...
Hank Knight
>Never heard of the artichoke one, Scott. I'll have to try it. Interesting.
Apparently.....
Bill Tindall, E.TN
>Wiley didn't consider his Iris extract to be one of his "favorite stains", but I will mention it anyway should someone needs some purple wood.
It's very light, almost sicking...
>It's like a wash coat. Just turns a light green on pine, poplar etc. Doesn't work on hardwoods.
I forgot, like most water dies it fades in the sun
