Trip Report
Trip Report
Trip Report
Doug Reynolds in Seattle
>Just returned from the Port Townsend, Washington School of Woodworking run by Jim Tolpin and friends. This was a weekend class called, "Plane and Simple". We learned to flatten the soles of handplanes, sharpen blade and otherwise fettle them for use. Then we flattened and prepare for use a very large piece of 8/4 poplar with cup, bow and twist. Worked up a sweat. The next days task was to take a piece of poplar, hand saw from a large plank, flatten both side, square the ends, joint both edges, etc. Once it was perfect, we ripped it in half, jointed a spring joint for glue up, and shot all ends on a shooting board. Then it was on to rabbet, plows, tenons, etc. all with hand planes. Good time had by all. See them at www.ptwoodschool.com.
Re: Trip Report
Re: Trip Report
Pam Niedermayer, Austin, TX
>Quite a productive weekend. Welcome to the light side.
Pam
Re: Trip Report
Re: Trip Report
LarryG
>Doug,
Would you please elaborate on the methods and techniques? I've heard of the "perfect board" exercise at the College of the Redwoods, but would like to know more detail.
Thanks,
Larry
Re: Trip Report
Re: Trip Report
Doug Reynolds
>Larry: The objective was to take a board in pretty rough shape and make it ready to use for furniture. We learned that one way to flatten a board with cup is to use a scrub plane and work on the two ridges produced by the cupping. We used wedges to keep the board from rocking as we worked. Once the ridges were mostly gone, we switched to a jack plane to get everything level, then a smoothing plane for finishing touches. On to a marking gauge to the smallest thickness marked all around the board then, back to scrub, jack and smoother. Joint and shoot square all edges and "done".
A very useful procedure is to rub the finished surface on the bench top, turn it over and you can see the polished surfaces and the low spots.
Re: Trip Report
Re: Trip Report
Now that's a great tip, don't know why I hadn't thought of it.
Pam
Re: Trip Report
Re: Trip Report
LarryG
>Thanks Doug (and Pam). I guess I wanted to know how you did the work (techniques and methods) rather than just what you did.
Any more tips?
