repair and glue used
Bill Tindall, E.TN
>One of the virtues of hide glue advocated by its proponents is that joints can be repaired. As I understand it, the joint is steamed and the combination of heat and moisture softens the hide glue. One procedure someone sent me involved drilling an access hole into a M&T joint and injecting steam to loosen a joint.
I am so frugal that I recover glue brushes, even when I have forgotten them for days. If they have yellow glue hardened in them a brief soak in hot water softens and then washes the glue away. This must be so as I habitually wipe excess glue on my pants and it goes away in the wash.
So my question is, is there any significant difference in taking a joint apart that was glued with hide vs yellow glue, given that each adhesive is readily softened by moist heat?
I am needing some considerable motivation to leave the instant gratification offered by a bottle of yellow glue with a practical expiration date of years into the future.
