DIY infill: Shaping the infills *LINK*
Craig D
>Working on the infills, using glued up Jatoba. I have a "no-handle" infill smoother that is really comfortable so I'm using that to guide the infill shapes. I tried a couple of times to make more traditional shapes but they looked really bad and felt worse (I grip the bun at about 45 degrees). The tote is basically my backsaw handle and is tilted forward quite a bit compared to, say, a Stanley. My wrist finds this to be more comfortable. The shape, uh, leans towards a tote-less woodie. Also, it is quite a bit wider than a Stanley: 1 1/4" vs 7/8".
The infill is interesting in that it is also a frog, sorta like a Bedrock. The entire infill moves back and forth. There is a big chunk of aluminum (the mouth block) mortised into the infill and that gets bolted to the sole. I've done this before, it works well and it takes a lot of stress out of fitting the infill to get the mouth just so. Personally, I think a teeny tiny mouth is over rated and this way, I can also use this plane as a jack.
Somebody asked about piening stainless, I tried a pin (as in a cross pin) and no problems, less trouble than the bronze ones I've done. Also, Wiley's new S&S narrow panel is stainless (and very beautiful).
Brazing 404 stainless: I tried both silver and brass brazing and both flow well. Actually, I grabbed silicon bronze (instead of brass) so TIG brazing should work also.
Craig
Blog entry
