OT - Calculating load on a gate post for bracing
>When our son built our gates last year, replacing old funky stuff, he put in a driveway gate for us: each half 6 feet wide, 5"8" tall at its highest (the gate top describes a catenary curve), 2" welded steel perimeter frame with a mid-height cross member, sheathed one side in redwood 1"x6". I'm not sure of the total weight (I know he put it in himself, but then he inherited somehow my railroad-mechanic uncle's knowledge of moving big stuff). It pivots on pintle hinges on a 6x6 post.
One side ties to full-height fence, and is fine; the other post is free-standing. On the free-standing side, he sank a concrete-filled deep hole with a 3/4" stud sticking up. We both predicted the post on that side would sag, but decided to see before investing in a brace from post to anchor. It did. I tightened the pintle on the top; it sagged again. Time to face up to a brace, which will be chain and turnbuckle.
I'm now trying to figure out how to calculate load so I can decide if 3/8" chain (working load 2,650 pounds) and turnbuckle, which is all our hardware store carries, is enough, or if I have to go to town to get 1/2" chain (working load 4,500 pounds, which should be almost enough to pick up my 1972 truck).
Re: OT - Calculating load on a gate post for bracing
Whew. Tough question.
>Bill, my partner and I built many driveway gates, most larger than yours, but I don't recall any that were installed to a freestanding post. Usually, they were anchored to a stone or steel post or fence. Theoretically, the concrete foundation should be rigid enough, but a 3/4" stud sounds pretty small to hold that kind of cantilevered weight without sagging. I probably would have sunk a piece of 2x6 steel channel into the 'crete and bolted the 6x6 post into it. The way we did it in the field was to weld a tubular steel column to a heavy 1" thick steel plate with 3/4" holes around the perimeter matching a pattern of 3/4" anchor bolts in the poured concrete. Each bolt had a nut under the base plate and one above it, so you could plumb the post by loosening or tightening the nuts as needed. You could also fine-tune it later if it deflected under load.
Without yanking the pad and rethinking the suspension, you're probably stuck with your turnbuckle fix. I don't know enough about the mechanics of the situation to recommend one chain capacity over another.
Chris Friesen
>Either one would be overkill. I'd probably use 1/8 stainless braided wire rope, which has a nominal strength of 1760 lb and is much less visibly obtrusive.
If you want to do the math, you'll need the weight of the gate. The gate will exert a torque on the post equal to
tau = r*F
where r is the distance from the center of the gate to the center of the post, and F is the weight of the gate. Assuming the cable/chain is attached to the top of the post, the force on the chain/cable is given by
F = tau/(r*sin(theta))
where tau is the value calculated earlier, r is the height of the post, and theta is the angle made by the post and the cable/chain.
steve mackay
>Hi, Mr. Overkill here ! Personaly, if I were going to be opening and closeing it, I'd go as heavy as I thought the whole rig would stand. 1/2" at least. Overkill the first time means never being sorry.
Noodling around about it......
Wiley Horne--So. Calif.
>Bill,
Sitting here trying to visualize the situation..... I understand there will be a chain-and-turnbuckle from the free-standing fence post to an anchor in the ground outboard of the post. The turnbuckle would allow you to adjust things over time, which is a good thing.
Murphy's law comes to mind, though. Is a neighborhood kid going to run into this chain on their bike, maybe in the twilight, and get injured? Maybe the turnbuckle needs to be screened off, so such events can't happen. Also, the overall gateway might be better balanced if there were more 'visual weight' on the freestanding side. This leads me to wonder if doubling up on the post on the free standing side (while still doing the turnbuckle thing) would help you aesthetically, as well as providing a safer situation.
Maybe what I'm saying doesn't fit, or maybe you're way ahead of me in your thinking, but just thought I would mention these notions.
Wiley
scott grandstaff
Re: Noodling around about it......
Scott Grandstaff
>Yeah, make it visible whatever you do!
I would go with a second post.
Your 3/8" chain and turnbuckle is plenty, but add a plank of wood or two, or anything of enough size it can be seen.
I am still a bit worried about the 3/4" rod leaning either forward or back.
You will take care of the gate sag with the turnbuckle, but that is only in one direction. The gate will swing all the way forward and back too I assume.
6" pipe would have been better than a wood post altogether. It wouldn't have --ever-- sagged if it was set deep enough.
Sometimes you can get 5" pipe for nearly nothing. Its an oddball size and people buy it by mistake and it lays in the boneyard pile behind every factory or plant.
4" pipe is probably plenty enough for a 1/2 gate, but its harder to get for free.
Find thee a scrap metal dealer!!
yours Scott
Thanks, all
>I misspoke a bit when I said the 6x6 post is free-standing. It is tied to the fence in one direction, but unbraced in plane with the weight.
The consensus over on Fine Homebuilding's Breaktime forum is that 3/8" chain is (a) sufficient or (b) more than I need.
It's aesthetically sturdy enough, so that's what I bought.
The chain will be located in an out of the way spot, right next to a building, at the back of the back yard plantings, and behind some large ferns. Any little kid running or bicycling in there would have a lot more to worry about than tripping over the chain - like getting sent to the corner for messing up the plants.
So, installation today or some time this week, depending how the list goes.
