New plane by Konrad Sauer *LINK*
Wiley Horne--So. Calif.
>Hi All,
I posted a couple of in-progress shots of this Konrad Sauer plane a while back, so wanted to share the finished product also.
This is a 16-1/2" panel plane, but is narrower than the traditional one. It has a 2-1/4" iron, rather than a 2-1/2" one. When we started talking about this plane, the goal was a panel length plane that was optimized on balance. Infill planes are heavy, and we wanted to find out to what extent the weight could be neutralized by balance.
I like a narrower plane, even in a woody, so this one was reduced in width by a quarter inch, which made it a bit lighter in weight. Typical bedding for a panel plane is the familiar Norris 47.5 degrees. We made this one 50 degrees, so that the tote/bedding block could be slid up closer to the middle of the plane (closer to center of gravity). Steel shoe is a big lighter in weight than bronze, and it looks good with ebony. The net effect is to put your hand closer to the center of gravity of a bit lighter plane.
Konrad fitted two irons for this plane. One was his standard O1 iron, made by Ron Hock. The second iron is one branded 'Elliott', as in Steve Elliott, and is from a small run of CPM3V irons made by Steve a few years ago, with key milling assistance by Bill Tindall, Phil Smith, and Bruce Norton in eastern Tennessee. These are great irons, if you don't mind using diamond media for sharpening.
I can't say enough about Konrad Sauer as a human being, and as a craftsman. He is the finest of friends, has a stellar character, and everything he touches shows the highest standard of design and workmanship.
Linked below is a set of photos taken by Konrad. He just finished it yesterday or this morning. There are 6 photos in the set--I encourage you to enlarge them to see detail, simply by clicking on them.
Wiley
Narrow panel plane by Konrad Sauer
Re: New plane by Konrad Sauer *LINK*
Jim Shaver - Oakville, Ont
>I saw this awhile ago in build on his bench, nice to see it done...
Ditto on all your thoughts about a fine man.
take care,
Jim
Ya know, Wiley...
>some of us share our computers with our life mates, and hate trying to explain why there's a huge puddle of drool on and around the keyboard.
Nice looking plane.
Brent Smith in Montreal
>What can I say?......It's a beauty Wiley!!!!
God, it's ugly!!!
Denis Ch�nard, Orl�ans, Ont.
>Kidding, of course, another beauty from Konrad :-)
Ditto about the man, deserves the utmost respect...
DC
Why no colour pictures ...?
>Just kidding of course, Wiley.
That Ebony-on-steel is just stunning (I am presently building a plane in this dress).
Karl's work maintains the very highest standards. This plane is no exception. It will no doubt inspire to to great heights, and bring much pleasure when in use, or just on the shelf in the woodshop where you can spy it as you do your stuff.
What you describe to balance the plane is very interesting. I like heavy planes, but some infills overdo this and end up fatiguing. I look forward to your user-account down the line.
Have Konrad and Karl met??? ;-) .
Wayne Anderson
>Stunning work. I've always loved the steel/ebony combination of materials. I can tell you that turning steel screws and making steel lever caps is much more difficult than brass, but the results are elegant.
It's one thing to have the skills to work with metal and wood; but to put it together and achieve that regal look and stellar performance is truly special.
Ditto on the comments on Konrad. I have met and spoken with him a few times, and found him to be a delight. I only wish I lived closer, so I could go hang out once in a while. -w
Re: Ya know, Wiley...
wilbur
>Hi Wiley,
That plane is just stunning.
You owe both Bill and me new computer keyboards. :@)
Just out of curiosity, would you happen to know how much prototyping went into this plane? Given the factors you were changing from the traditional model, the change from bronze to steel, and your goal of optimizing the balance of the plane, it seems to me that there were many pitfalls to avoid.
Re: Ya know, Wiley... *LINK*
>Wilbur,
Konrad's discussion is better than mine, so there's a link down below to the plane maker's own words.
Konrad makes custom planes, one at a time, so each plane involves back and forth with the prospective owner--choice of shoe material, infill wood, bedding angle, mouth gap, and other details. I can tell you how this one evolved.
He was confident from the outset about the build, because the components had each been worked out previously on other planes. For example, the problem of sliding the rear infill/tote forward, closer to the center of gravity, had been worked out on an A5 (A5 = coffin shaped, toted smoother).
On the A5, the problem had been to shorten the face (sole) of the plane to 7-1/2". This was done using York pitch and subtle changes to the tote. Surprisingly, these changes which were made to shorten the plane, distinctively improved its balance. As Konrad says, it put the weight of the plane in your hand (as opposed to loading up your wrist). So that part had been proven, and was applied directly to this new plane. He had already made a number of steel shoes, including for a jointer, and knew how the O1 would peen. 2-1/4" blade width was new for a panel/try, but was standard for a smooth plane, so he had the lever design. There was a new detail used on the bun, but that detail was standard for jointers--he knew how to execute it, and how it would look.
He did have to change the side profile and cross-pin/lever placement to match the bedding angle change. He did that in his CAD program, and emailed that to me for approval. (Like I was going to disagree (<:)).
His concern from the start was not the build, but the look--what would be the visual effect of tighter sidewalls? He borrowed a detail from his jointer design (jointer also has a long narrow aspect)--and that single change seemed to make this plane look right. Konrad was a design professional in his earlier 8-5 life, and he seems to know how a single change can make all the difference.
Wiley
Konrad Sauer's take on a new design
NO WAY!!
Jim Shaver - Oakville, Ont, Canada
>Konrad uses CAD????
;-O
Jim
If it makes multi-color
>line drawings and does scaling, I call it CAD. Are you one of them there black belt guys, Jim?
Wiley.... who remembers when the IBM 360 was a big deal, and you programmed with a screwdriver (almost)
Re: If it makes multi-color
Dan Donaldson
>And Fortran, and punch cards and EMACS and ...... ;-)
Programming with a screwdriver
>One of my HS math teachers had a computer that you programmed by moving wires to different terminals; it sat in the back of the classroom. He was as proud of it as a new father. We all thought he was completely out of it (even a little more than HS students think their teachers are out of it).
Awww, c'mon, it's kinda funny....reread Derek's
Those preceded the 360
Pam Niedermayer, Austin, TX
Re: Awww, c'mon, it's kinda funny....reread Derek'
>It was a slip of the pen! :)
... most interesting - from this you see just how highly I consider Konrad's work. Perhaps not technically as perfect as Karl's (who is?) but Konrad's has infinitely more soul!
What about flow chart templates.....
Joe Rogers, Northern Virginia
like this?
Dan Donaldson
Re: like this?
>You know, I bet I've still got several of those templates laying around in a drawer somewhere, indestructable plastic.
Pam
I probably do also.
Dan Donaldson
Is there another WAY!!
Scott Burr in Ben Lomond, CA
>Not if you want to stay a step a head ;^)
Of your own work demands of corse, medium or fine...
Wouldn't that be CAM?
Old Skhool...Yea!
>Now it's powerpoint or viso...
