Cutter style for Stanley 45 combination plane?
Charles R. Smith
>I need some advice... I have a Stanley 45 combination plane (Sweetheart model) that I bought from the widow of a deceased acquaintance. Unfortunatly, only one cutter could be found.
I have a chance to buy a set of cutters for a Stanley 45, but they have a small round hole at the top of the blades (which I presume are for depth control), whereas my model of 45 has a small rectangular cutout or slot at the top of the cutter.
My question is this: will a hole-type cutter fit into my model?
Re: Cutter style for Stanley 45 combination plane?
William R. Drylie
>Charles:
I have a Stanley 45 (also Sweetheart era) and the blades that came with had the slot. I've never seen 45 blades with a hole instead of the slot. If the hole is sized and located so as to fit the pin on the adjuster I don't see why it would'nt work. When I got my 45 it was missing all but one of the straight blades. I had my brother-in-law mill a slot for me in some O-1 steel and made a set of blades. If I had thought of a hole I could have done it myself.
Bill
>I've got one cutter with a hole which, because it's a redundant size, I'd never tried. I just did, and the hole, while it accepts the pin on the adjuster mechanism, won't permit the cutter to seat firmly against the side of the blade bed. This side bedding matters, since it aligns the cutter with the edge of the skate, provides (I believe) a hefty chunk of the solidity of the bedding, is important.
If you have more time than money and the cutters are significantly cheaper than stock cutters for a 45, you could (probably) buy them and file the hole to a slot; otherwise, I'd look for cutters with slots.
One additional note: some of the narrower 45 cutters are unslotted, and designed for the adjuster mechanism just to push them forward; retracting is done by your fingertips pulling them back. You could, perhaps, use these cutters the same way, but it's a bit awkward.
David Miller from Iowa
>The cutters with the holes are very old - from the first couple iterations of the plane. As always, the corporate cost cutters determined it was much cheaper to just grind slots in the sides than drill holes. The cutters should work fine, and you have the benefit of knowing they are the musch older scarcer set.
George Moore
>I am not sure this is what you are looking for but if it is it is a good buy.
http://www.stanleytoolparts.com/cusetwiwa1.html
These have the notch at the top.
George
WOW, Thanks Dave!
Scott Burr in Ben Lomond, CA
>How would have known. I've never seen a 45 blade wit a hole. Good to know there original. That said, I wouldn't touch them...
Thanks again!
