working with brass questions
Edward in Vancouver
>I'd like to make a shop compass out of brass, legs maybe 7" long, 3/16 square, riveted together and the legs adjustable with the wingnut and arc system.
I've got a hunk of "360 free cutting brass" leftover from another project that I'd like to use, it's 3/16" thick. I'd like to partially turn the legs about 3" from the bottom on my little ol' crpsman lathe.
The leftover brass was orignally procurred to make toolbox handles (back issue of "shop notes"....) for a tackle-box style toolbox. I suprised myself on how easy the brass cut on a tablesaw with a cheapo carbide blade. The strips of brass were for handles for the toolbox, and were heated with a torch and then bent into shape.
-With this project, do I need to heat the brass once it's completed (machined and shaped)?
-Is 3/16" thickness too "wimpy" for this application? -
-I've fooled around with a few scraps on the lathe, and was able to "turn" the brass with an assortment of files and abrasives. What other tools would normally be used?
-If the brass is too soft, what other metal should be used? I don't think strength plays a role here, but ease of shaping does.
Thanks
Re: working with brass questions
Pat Riley in SLC
>I do not think brass is too soft for this project at all. I turn brass on the lathe all the time. Along with files and abrasives, I also use my high speed steel turning tools. They will cut just fine, and for quite a while before you need to sharpen them.
If it was me, I would make the entire thing out of brass, but make two pointed steel inserts - about 1/16 diameter - for the points. Just epoxy them into holes in the ends of the brass arms. I think brass points might be too soft. You will have to use just files to make the points on the steel, but that isn't that hard.
I would also do the project in two stages. Do the initial work on the brass and steel. Then insert the tips and let cure. Do the final fine tuning on the lathe with the points in place.
Post some pics when you are done.
Pat
ThomD
>When brass is overworked it hardens, which may not even affect a gentle use such as the one you have in mind. But if it did, you can heat it in an oven to restore ductility. This is comonly done with cartridge cases that have become hard from repeated firing. Any brass you don't want softened can be left immered in a tray of water.
Machining does not require any post treatment. Brass can actually be turned with woodturning tools. Fine scrapers.
Edward in Vancouver
>Thanks gentlemen, I'll be trying it out next week.
We wanna see pics!
Scott Burr in Ben Lomond, CA
>Well. I do anyway...
Sounds like a fun project!
