Block plane repair
Block plane repair
Block plane repair
Joe Grittani
>Another day, another question.
I recently picked up an older, but not real old, Stanley 9 1/2 adjustable mouth block plane. The pin that the mouth adjustment lever rotates upon is gone. It appears to me that said pin is a friction fit in the hole in the body and then gets peened over the top of the lever and filed off.
Not being experienced with metal work, I'm trying to figure out if my notion is correct and what to use to replace the pin that would be soft enough to friction fit and peen over without cracking the casting.
Any guidance will be greatly appreciated.
Joe Grittani
Re: Block plane repair
ThomD
>A piece of stainless welding rod might work. Any piece of mild steel like a nail should also be peenable. Just hit it with a hammer and see if it deforms.
One of the first things I did with my record block plane 30 years ago when I bought it was remove the mouth adjustment lever. It isn't all that useful in adjusting the mouth, and I found when I tightened the retaining knob the cam lever used to move out of position due to the rotation of the knob against it. I don't know if this will prove true for you, but I probably wouldn't be rushing to fix it.
Tom MacGregor
>The small brass "eccentric lever" that adjusts the width of the mouth opening should have a pin attached, and the lever & pin should lift off as one piece when the front knob is unscrewed. I'd look for a replacement - no hammering involved. I'm sure lots of folks who frequent this board have a spare or two kicking around. I'll check the bone pile this weekend.
ThomD
>Theoretically, and depending on how orriginal you want the thing to be, you could tap the hole and use a screw. Normally one would use several taps finishing up with a bottoming tap for a blind hole of short depth, but you might get way with sanding some taper into the screw and forcing it in for good retention.
>It's not a friction fit; it's a moderately free fit, with the pin being force fit into the eccentric lever.
They're not absolutely necessary, though I do prefer mine. You might try finding a washer (I'd go for brass, because they seem to be a little smoother usually) that fits the clamping bolt, and see how that works.
Stanley still lists the eccentric for cheap, but the shipping is expensive for small orders, relative to the cost (you might pay $6 shipping for a $2 item). Almost any of the online tools and parts folks should be able to provide you one. I've had good experiences with Clarence Blanchard at Fine Tool Journal and Walt Quadrato at Brass City Records (Google the company names; Clarence responds to his e-mail, but it's better to phone Walt).
scott grandstaff
Scott Grandstaff
>If you'd grabbed a finish nail, nippers and a file, maybe a small hammer for peining a little,
you'd be be done by now.
You couldn't make a call or send a postcard as fast as this job would take.... and its free.
yours Scott
Or perhaps a roll pin
>I've used these - any hardware store has them - more than once for similar applications. They're spring steel, designed to compress as they enter a hole, although they're also soft enough that they can be peened.
Joe Grittani
>Thank you one and all. Once I realized that the pin was not really anchored into the casting but one piece with the adjustment lever, I cut off a finishing nail small enough to fit through the hole in the adjuster. A little crushing and piening and Bob was my uncle.
Joe
