We value your privacy.
>Can't help but be struck with the irony associated with the fact that all competitors used to copy Stanley models and innovation, and now Stanley is seeking to catch up to Lee Valley and Lie Nielsen.
Re: It seems the new Stanley planes are almost out *LINK*
>Rob, I would think that the one-piece construction would actually lend itself to more problems of alignment than less because of warping, etc in the casting and finishing processes. Am I right?
A complicated question... to which the answer is - maybe... :)
Certainly, machining on a low angle blade bed is tougher, and tolerances have to be held higher, to avoid bed skew. From the standpoint of the casting - the extra mass of the bed may give porosity problem in the casting back of the mouth.
The again, mating a frog to a body can present a whole other set of tolerance/control problems - as now you're wourking with 3 machined surfaces... but also have the advantage of being able to adjust the geometry somewhat.
Then too, it depends on the production equipment you have, and the quality of your fixtures...
Cheers -
Rob
>You sound like a process engineer, LOL.. yes porosity is the bain of all castings in any material.. harmonic resonance can be used to evaluate castings for density as well
Take care,
Jim
Wondering if Rob knows how find equilibrium with all his X, Y's and Z's ... and knowing the answer is yes, maybe...LOL
Only those who have spent hours on a milling machine holding tight tolerances can fully appreciate what you are saying. Even the temperature of the room can effect accuracy and consistancy.
A Jig Boring machine, the Mother of all milling machines, must be operated in a temperature controlled room in order to prevent even the machine itself from expanding and contracting too much.
Marv
>Like a good piece of beef, cast iron needs to be aged. Just let it sit in a somewhat controlled environment and let it relax after forging casting whatever. After a few months then it's ready for finishing. No warp twist or other nasty things happen like you'll see on old stanley planes. Working un(non)-aged it's kinda like squating and flattening a green piece of wood... It's not gonna stay that way for very long.
Cheers!
So, the aging is to allow the casting to do it's warping and twisting before it is machined? Sometimes, depending on the design of the casting, it can move when metal is removed.
Marv
>Depending on the piece being finished it couls, duh WOULD be restrained in the -A-, -B-, and -C- datums. Also it might be shimmed up or pressed down before the process to hold nice tight tolerances.
Oh yes, Let's not forget the 2 pass machining process as well.
Todd Hughes
>I would never buy anything like that when it is so easy to pick up old high quality vintage planes but they are sort of interesting.
I would imagine for a modern made factory plane they are probably made as well as any and I bet alot of people will buy them. If I was LN or LV [esp. LV whose market they seemed more aimed at] these might would cause me some sleep less nights.
I could be wrong but I wouldn't hold my breath waiting for some fair and impartial testing of them.
I would love to see a blind test where work planed with these planes, LN and LV ones and maybe even antique Stanleys are shown to "experts" and have them match up the work with the plane that did it...Now wouldn't that be an interesting and novel way to test something by the actual work it produces?
I think they need to get a better person writting the add copy, description pretty weak and flat. Photos could be better to esp. if they included some action shots with shavings on an old bench etc.....Todd
Todd - surely ease (even joy) of use should also be a factor?
