Dominy Bench Questions-long
Patrick Gibbons, Katy, TX
>I decided this year was the year I built a new bench and a tool chest. I have always wanted to build a bench with a slab top and had planned on buying a SYP beam from a local supplier here in Houston. But the supplier sells timbers and so the drying process is not as careful as what I need. Cracks develop and I believe I would experience more problems than I would be able to deal with easily. I wish I had a better understanding of just how wet bench tops were in Roubo's time.
I've gone back to looking at Dunbar's Federalist bench which he detailed in Fine WW (it's really the same as Holtzapffel's bench, I think), the Roubo-style bench that Roy Underhill built, and the Dominy benches mainly. There are others of course but the main issue is building a two piece benchtop. The main portion of the top is a thick, wide slab that is rabbeted at the back and a thinner plank is connected to it to make up the necessary width for the top.
Dunbar screwed a piece of birch plywood to his plank. The Dominy benches were red oak slabs with a hardwood plank. I wonder if anyone knows how they were connected? There are end caps on Dunbar's but none on the Dominy benches. Underhill used endcaps, a tongue and groove and a tool well on his. The Shakers used endcaps and bracing underneath.
The next question concerns the back legs. Underhill attached the back legs to the main slab, Dunbar attached longer back legs to the secondary wood. The Dominy benches have splayed back legs as does Underhill. How are the back legs of the Dominy benches attached? I hope someone can shed some light on these two questions for me; 1)How were the secondary pieces on the Dominy tops attached to the primary slab? and 2)How were the splayed back legs connected?
