Followup to Wiley's iris experiment
Bill Tindall, E.TN
>Recall that Wiley accidentally applied a mixture of purple iris blossom and water to a piece of finished maple and it stained the wood. Because this accident could happen again I thought it useful to do some experiments to see how iris color, or other plant derived color, might be rendered colorless.
The dye from purple iris petals turned out to be easy to extract with water making the combination of iris and water a means of staining wood purple as Wiley discovered. It is little wonder the purple penetrated somewhat into the curly maple. Wiley observed that Nital, a combination of methanol and nitric acid, appeared to more or less bleach the color. This procedure would not have been the first thing I would have thought to try, but discovery can take unexpected paths.
The best way to explore color removing chemistry is to do the experimentation in solutions and not on furniture. After extracting the iris dye into water I divided up the purple solution in wife's ramekins and retired to the lab (AKA laundry room where the chemicals are kept).
The first thing I discovered was that iris dye acts just like red cabbage dye and it may be closely related. Upon adding vinegar*acid) to the solution the dye turned red, addition of washing soda (neutral) turned it blue, the addition of ammonia (weak base) turned the dye green and lye (powerful base) turned it yellow, just like red cabbage demos in middle school. What a great project for science fair.
The Nital would have turned the stain red/pink. I am not sure if the Nital would have bleached the dye; I am skeptical that it would have. Sadly the laundry was out of nitric acid and I could not test this hypothesis.
Next I confirmed Wiley's observation that pharmacy hydrogen peroxide, with or without ammonia, did not bleach the dye. Clorox immediately turned the dye yellow (Clorox is very basic like lye so this color change was expected) and after a bit the solution went colorless.
Conclusions: Nital will turn the dye red/pink but I could not confirm if Nital will destroy the color. Clorox will destroy the color and maybe the furniture too. These are the kinds of experiments one does when one is facing a huge resaw job on wide stuff that has me intimidated. I need to suck it up and get on with the resaw. Daughter wants her dining table out of cherry and all I have suitable for the job is 8/4 to be sawed to 5/4. What a waste. I had fabulous walnut for the job but that was not to be.
Re: Followup to Wiley's iris experiment
wilbur
>"I had fabulous walnut for the job but that was not to be."
Well, based on your recent experimentation, the solution seems obvious. Take the walnut, use some combination of Clorox and nitric acid to bleach out the color, and then use pH balanced red cabbage dye to make it look like cherry. :@)
I have another daughter
Bill Tindall, E.TN
>maybe she will want a walnut table. I could experiment with your suggestion and put off resawing another day............
Source of stress- previous experience, 14 " band saw with 3/8" blade sawing curves in thin replaceable stock.
Task at hand,new to me rebuilt 20" band saw with 3/4" "log sawing blade" resawing 8-11" wide stock and I just have enough for the table.
Why not just go get some 5/4 cherry?
Scott Burr in Ben Lomond, CA
>It's seems to me that resawing 8/4 cherry is a true waste of a nice thick boards.
