Need advice on height of planer blades
Charles R. Smith
>I am tuning up a thickness planer and need to know how high to set the blades. It's a (very heavy!) 13 inch, Delta Invicta model, made in Brazil in the 1980's. Unfortunately, when I bought it second hand, it lacked an instruction manual, and the blades were all set askew.
My question is this: do I set the edge of the blade to the same height as the surface of the cutter head, or higher? In other words, if the outside surface of the cutter head describes a circle having a radius of 2 inches, do I set the blades at a radius of 2 inches or 2.00x inches? I can measure and set the blades to about a thousandth of an inch. I was thinking of setting them about 0.002 inches above the surface of the cutter head.
Your thoughts? I appreciate your collective wisdom!
