Stanley 30 angle divider *LINK*
>We live in an old house, in which, naturally, there are no right angles. There are plenty of 89-degree and 92-degree angles, but nothing at 90.
When I remodel/refurbish a room (not all the time, it's working out since retirement to a big project about once a year, though none this summer), I've been taking off the angle with a sliding bevel, measuring the degrees with a machinist's protractor, then dividing by two to get the miter angles needed, and setting the miter box or sliding bevel as needed.
Is there any advantage to an angle divider, like the Stanley 30, other than speed because it does the math directly?
second picture in this link
Re: Stanley 30 angle divider *LINK*
Yes and No *LINK*
David Miller from Iowa
>I have a couple of these and they work well for what they are intended. However, I can't measure or mark well enough to make it worthwhile. When I need an odd shaped piece to fit exactly I generally "ballpark" it and then mark it off the irregular piece with the tool shown in the link.
One of my favorite "go to" tools
Clamp bolt sizes on Stanley 30
>David, I sent you an e-mail on this, but if someone else can answer, that'd be great:
I'm interested in the diameter of the clamp bolt on a Stanley 30 divider, and the width of the slot in which the head of that clamp bolt runs. There's one on deBay missing the clamp bolt. If the dimensions are right, I might be able to use, say, a toilet bolt as a replacement.
Cancel question
>Not keeping up with my e-mail -- I've got a response early today from David. Thanks!
