Info for those that spray
Bill Tindall, E.TN
>I recently ordered a 3M PPS kit. I saw this product when it was introduced several years ago at IWF. Seemed like a good idea but I never got around to ordering the stuff....available at most auto paint suppliers. The seal on my cup leaked badly and I needed to do something about finish running out onto what I had just sprayed. Rather than buy a seal I ordered the PPS and junked the cup.
I am smitten by the PPS system. One can spray upside down, sideways, what ever. If you throw away the liner the gun can be cleaned with a tablespoon of solvent. Depending on what I have sprayed I often clean the liner and reuse it(I am frugal). Left over material can be sealed in the liner for later use. This feature is especially nice for many projects.
The picture shows the system. Starting at the gun there is an adapter, the cap with integral filter, disposable liner and liner holder. Not shown is a cap that holds the assembly together. It works like a modern baby bottle. It is not vented so nothing can leak out. As one sprays the flexible liner collapses around the remaining finish. Three sizes of liner are available. Show is the smallest.
Re: Info for those that spray
Wiley Horne--So. Calif.
>Bill,
I've never sprayed at all, so I have a dumb question. What is a sensible cost-effective air compressor to use with this 3M system?
Wiley
I'm picturing...
>the apprentice blowing really, really hard into a straw at the nether end of the tubing.
compressor
Bill Tindall, E.TN
>The capability of the air compressor is not determined by the container that holds finish, but rather the gun. This is an old fashioned gun and it doesn't take much air to work properly- 35-40 psi and I don't know how many cu ft /min. I have run it off a tiny compressor when spraying in a remote location. At home I have a big honker that I bought to drive air sanders. lf contemplating getting into spraying go to an auto paint store and look at quality guns. They will come with specifications as to how much air they need.
Some like the HVLP guns that use hurricane quantities of air at low pressure. In my hands they don't atomize as well as a conventional gun and they are more demanding of technique. And they require a high volume source of air.
Re: I'm picturing...
Pam Niedermayer, Austin, TX
>Odate taught me how to do this with water (on rice paper). Very funny.
Pam
Re: compressor
>I've used HVLP and they work just fine, pick up a vacuum cleaner somewhere and set it to blow out. Just keep the gun moving.
Pam
Tom Colligan
>Hi Wiley, after reading Rob Millard's blog and his high regards for a particular water based lacquer I too am about to take the leap to spraying. I think I'm going to work with Jeff Jewitt. The HVLP guns he recommends require a very sizeable compressor. The spec needs are listed and when I looked at a compressor that size it was enormous and costs in the neighborhood of $400, ugh, since this is just for the compressor.
I don't agree with either recommendation
Bill Tindall, E.TN
>I would not agree with either recommendation. A HP gun set up is cheaper, more versatile (because the compressor is more versatile like for blowing off projects or cleaning the shop, inflating tires, etc.) and is easier to learn.
solvent based lacquer is a better finish, and sprays easier.
Only if you must spray in a confined space would HVLP and water based finishes be a preferred choice.
compressors
Adam Cherubini
>When you think about compressors, you need to seperate out the size of the tank from the capacity of the pump that fills it. If you had 1000 gallons of air, at 100psi, you could do a lot of spraying. If it took all night to refill the tank, that might be okay.
Often times pump power and tank size are coupled needlessly (like trim packages and engine size/hp on automobiles). I wonder if I couldn't get a tiny pancake compressor and hook up an array of freon cans or the equivalent to it to increase the size of the tank.
I think what guys interested in spraying do is choose a compressor with a pump that provides enough pressure and volume to run the sprayer. This basically assumes that you have nothing in the tank. And that is what is required for continuous spraying. But for shorter bursts, if you had a large tank, it would take awhile to reduce it's pressure and you could always wait a minute for teh pressure to come back up before the next blast.
I have a 25 gallon craftsman compressor (for automotive work) and it's really loud. In fact, I don't like to set it to auto since it scares me when it switches on and I've hit my head a couple times as a result. Also- I've found I don't like using air rachets. But I love my impact gun. The impact gun needs high pressure but a pretty low volume of air. I could have gotten away with a much smaller (and quieter) compressor. If you spray like I use my gun, in theory at least, you could do the same thing.
If you choose to buy a compressor with a big tank, the vertical tanks take up a lot less space.
adam
Re: I don't agree... and compressors
ThomD
>"Only if you must spray in a confined space would HVLP and water based finishes be a preferred choice."
Not true on a lot of grounds. HVLP are prefered for wasting less material, if you are shooting stuff that is 200 a gallon, as with LPUs it is great to have low blowback, not to mention the fact you really don't want it coming back to you. There are environmental reasons also, which even without worrying about the earth can be a big issue if you have OSHA types floating around. HVLP also shoots some stuff better, like latex.
If you were talking about toxics like Isocyanates, the Bhopal stuff, then you need positive air pressure breathing systems regardless, unless personal issues are getting too heavy, and Kavorkian isn't any longer available. I would say either spray option is out of the question without it.
High pressure gear as mentioned has many advantages also. The guns are relatively cheap, so you can have both. Good guns are expensive, but not necesarry for everything. We have had reasonably good results with HVLP guns selling for 20-30 bucks, and they come in happy anodized colours.
As far as compressor size is concerned, you pretty much want as much compressor as you can hang on a 110 outlet. That should be a mobile rolling unit, but not easy for one person to carry. It should also be the right size for framing stick nailers, etc... A better unit would be the biggest thing you can hang on a 220 outlet, but you can get by without. Keep in mind a critical factor is how much you will be running the gun. If all you want to do is shoot a guitar, then you can get by with little squirts and rest the compressor while it re-compresses the resevoir. Same thing when running sanders, but they will use a ton of air, so bigger compressors provide a better duty cycle.
My neighbour had his brother living with him for a while and that guy started a business spraying driveways. He bought this excellent looking pump that could handle sludge like liquids. He used to be an industrial help desk guy for the company. And was in love with the machine. He had a 20 hp gas compressor to power it. He could spray the driveway sealant that comes in those 5 gallon tubs. Very efficient process. He would also spray just about anything, including epoxies fortified with sand. It was a bit smelly next door while he sorted his business out, but I did get to see some very heavy duty spray gear.
Hmmm the only thing that spray at my house...
Scott Burr in Ben Lomond, CA
>Is the cats.
