DIY Stainless Steel Infill Kit *LINK*
Craig D
>I've started to build the DIY Stainless Steel Infill Kit I got from Andy Lincoln via a benefit auction. The plates were cut with a water jet and are very nice.
So far, I've made a cap screw and roughed out the lever cap. Andy was kind enough to include a Norris shaped cap blank cut from 1/2" plate, a massive piece of metal. I put it on a diet and reshaped it to be more Spiers like. The screw I turned from a 1" rod of titanium. It has a pseudo pagoda shape.
The blog entry has some photos (which are too big to include here and there is more than one).
Blog entry
Re: DIY Stainless Steel Infill Kit *LINK*
ThomD
>Good luck, and good start!
I was looking online and there is 304 stainless C channel which would be a cool material to make a plane out of.
http://www.discountsteel.com/index.cfm/go/main.itemDisplay/itemID/119.htm
How would you cut this stuff?
Pam Niedermayer, Austin, TX
Hacksaw works fine
Raney
Craig D
I've looked at using channel for planes and found a couple of problems: the channel isn't square (inside, makes it difficult to fit an infill) and the sides usually are not tall enough. Thick walled rectangular tubing might work pretty well.
Also, you might want to look for 303 stainless if you are going to cut it, it is made to be machined. But you can't weld it. If you don't sweat, skip the stainless and use mild steel.
Craig
Re: How would you cut this stuff?
Craig D
>A hacksaw works but is [really] slow, about 1/2 the speed of mild steel (for my power hacksaw). Files work. If you have to tap it, you really won't enjoy it. Ditto if you want to mill it. Hole saws work great. No problems drilling.
One thing to keep in mind is the above is for 304 stainless. 303 stainless is much easier to machine.
Craig
Craig D
>Opps - forgot the best ways to cut stainless: water jet or laser.
Craig
>Like the sound of water and laser. Thanks, guys.
Pam
ThomD
>Around here the cost of either is prohibitive. It's 60 dollars to set up the job. So it makes sense to do if there are multiple parts and lots of buyers.
One would have to machine the C channel, and even then it wouldn't suit a lot of shapes It is a traditional craft so getting the traditional shapes is probably mostly a job for the traditional methods. It might make some lower modern shapes I have seen.
I am really interested in how it will peen. In stainless I might have been tempted to cut normall dovetails and braze it with 45% siilver since it would make a nice like of contrasting gold.
>Good thing I'm very happy with plain wood versions. :)
Pam
Re: Peening stainless
Craig D
304 stainless (which I am using) is very ductile (it is used for deep drawing of parts), and while I haven't hammered it, it bends quite well and I suspect it will peen equally well.
I need to experiment with silver brazing (I use 56%), I have some stainless (I don't know the alloy, it might be 303) that absolutely hates to be brazed. Failing that, silver soldering (6%) is strong enough, but the color doesn't match.
Craig
ThomD
>I like the idea of the colour not matching it would provide a decent contrast, of course the lines would have to be consistant in width.
I wouldn't have thought the stainless would be all that ductile at the working forces involved, compared to brass. Good luck with the project!
Marv....... Northern California Lake Co.
>Craig,
Silver solder should work quite well. It flows much better and at a lower temperature. The higher the silver content the better. Fluxing is very important. I like the paste type flux that you mix with water for the right consistancy. Cleaning off the cystalized flux after soldering can be a bit of a task.
Marv
ThomD
>Since this is a woodwoking forum I would caution that some older silver has cadmium in it, and occasionally shows up on ebay at great prices. People did use the Cad stuff over careers, so I suppose it is surviveable for a single careful use, but I wouldn't use it. I use safety silv flux and it is very easy to clean up. 56% flows better which is nice with tight fits, but crank up the heat, and 45% will flow also, and it has it's advantages for fillets etc... I kinda prefer the 45% for the majority of the work I do. The 45% seems yellower, which at least in my mind would be an advantage in this use. The heat level should be irrelevant with 304.
Re: Silver solder & stainless
Craig D
I also want the dovetails to be visible (vanity). If the joint is tight, the filler isn't visible (a silver brazed joint is strongest if the gaps are 1 - 3 thou). I'm considering using brass shim stock between the side & sole (on the visible vertical edges) as accents (like the Inca wooden dovetails).
Another safty note: the Stay-Silv White Paste Flux is nasty stuff. I try to use a organic vapor mask when I'm doing much brazing.
Marv - there are two types of silver: 4%ish w/tin (if I recall correctly) that melts at ~400F and the high silver content stuff that melts at 1200F (the stuff I use). Tensile strength is ~15k psi vs 85K PSI. Both flow nicely (I use oxy/acetylene for both). Brass melts at ~1750F. On some type of stainless, the 56% just does NOT flow. Haven't tried the 4%.
Craig
