A use for old woodturning chisels------WebKitFormB
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
>I got a set of old Buck Brothers chisels with an old lathe awhile back and hung them up on the wall. After awhile I looked at them and thought they would be useful for paring wood. They are single bevel and have blades of 6 to 8 inches. Of course, the handle is fairly long since they are turning tools. Based on the vintage of the lathe, these are fairly old and I assume they are carbon steel. I cleaned one up and used it and find it works very well to trim plugs and pare dovetails flush. These are the style that was called long and strong, with the blade tapering in thickness toward the edge. Most turners don't like carbon steel because it dulls so rapidly at the lathe, but using hand pressure the edge last quite a long time. So if you see some old lathe chisels, either skews or straight edge, consider trying one out for a paring chisel.
Roy Girolami
Apex, NC
------WebKitFormBoundary9yANUT8mn8C+ZoYg
