Re: Weather resistance
Wiley Horne--So. Calif.
>Bill,
You've brought up an interesting idea. Now in my case, the cast iron still had enough original coating that there was no apparent dissimilar metals corrosion from the brass fasteners. Plus, you have to have an electrolyte (water) present for much to happen, and it's pretty dry here most of time.
In Sebastopuddle (Sir Wm's phrase) or in Iowa, might be different. The amount of iron in a bench casting would make a pretty big sacrificial anode, I will allow that.
I'm not sure what would happen in a wet environment between brass fasteners and iron frame. If you look at a ranking of the metals, the iron should corrode first in the presence of the brass. However, yellow brass has a lot of zinc in it, and zinc is way ignoble, so it could be that each brass nut could have internal battery action, if wet. Big if.
Oh well, I didn't see any corrosion, but the brass had formed a dark ugly patina, so I replaced with the stainless. As I understand it, the stainless (exposed to air) will form an initial dull patina, and then be inert thereafter.
Wiley
