Stopped Grooves
David Brown
>I was wondering if the collected wisdom of this august group could help me as I prepare to make some dovetail boxes. They will be used for 2 things: As storage for kids toys and to allow me to practice cutting dovetails!
I have a Record 044 plough plane but not the LV large router plane I want.
I want to cut grooves for the bottom of the box and I have a couple of choices:
1) Cut through grooves all around and live with the gap that will be present.
2) Cut through grooves all around and plug the gap (I got this idea from a search on "stopped groove" on WC. Thanks to Bob Demmers)
3) Cut through grooves on 2 sides and cut stopped grooves on the other 2 sides and lay out the dovetails to hide the through grooves.
I'd like to do option 3, but I'm not sure of the best technique to cut 1/4 inch grooves with the grain in a 12" long board and have it be consistently 1/4" in from the edge and be exactly 1/4" wide and 1/4" deep. Something tells me this technique might involve a chisel. I do have a 1/4" one. I've seen techniques described for cutting dados with a saw and chisel, but I don't own a saw that would allow me to cut a 12" wide groove prior to clearing the waste with the chisel.
I thought I saw something by Christopher Schwarz on cutting stopped grooves with a plow /plough plane, but I can't find it by searching his blog. I could be making this up. I can't see using that tool for a stopped groove.
So how does one do this with limited tools? If the answer is basically, buy the router plane, I'd like to know that as well. I'm new at this, so please be kind in your responses.
Have a good night.
--Dave
