REAL MILK PAINT
Ryobi question
Ryobi question
Ryobi question
roninkokomo
>I got a new ryobi several months ago and used it to make some stuff for my wife's school program.
Question.... I knife the line I want to cut to, and am able to cut a pretty straight line. When I apply a square to the thickness of the board, I find that I must be tilting the saw to the left. ( I am right handed).. I consciously tried to ease ups the the place that there was no downward pressure at all on the saw, and this seemed to help some. But, in 20 different instances, I only got three that were square in both dimensions. Suggestions??
Now, they weren't awful, But I would have to trim them with my Lion Miter trimmer before I'd use them as a finished cut.
Re: Ryobi question
Re: Ryobi question
chuckbeck in cent il
>I always like to watch the reflection on the blade, if there is error it is easier to see.
Re: Ryobi question
Re: Ryoba question
Pam Niedermayer, Austin, TX
>Might be a good idea to try a two-handed, two-footed stance for a while. Get it started and then let the saw do the work.
That said, a ryoba is inherently fallable, that second set of teeth will put the saw off track if the second side is subsumed by the wood. And it may be a little flexible for what you're cutting. So you may want to try a dozuki or kataba.
Pam
Re: Ryobi question
Pam, is there a one-footed stance?
Re: Ryobi question
Re: Ryobi question
wilbur
>I'm right handed, and I have a tendency to tilt the saw to the left as well. As Pam said, once you get your cut started, try pulling the saw with two hands. You already have figured out the other main tip, which is to let the saw do the cutting, and really try not to exert very much downward pressure on the saw.
Another way to correct this is to hold the handle of the saw as far back as possible if you are sawing one-handed. This will minimize any tracking error.
One other thing to consider: what kind of ryoba are you using? Although the various machine made replaceable blade ryobas are quite good, the handmade ones have one big advantage, and that's a taper as you move from the saw teeth on either side towards the middle. This provides a bit of clearance that helps keep the saw going straight by minimizing any binding that might occur as the saw gets deeper into the kerf.
Re: Ryobi question
Well, of course. Storks?
Re: Ryobi question
Re: Ryobi question
MikeW
>Eastern or western, and regardless of handedness, a sawyer will often have the same through the thickness error. That is, the back-side of the cut will be "long."
The Eastern saw user can often improve the margin of error by using the stance that Pam writes about. I would only add--and it is pretty self-evident when one tries to use the two-handed holding--is that the saw needs to be pretty centered on one's body. One foot back from the other (for me my right foot is the one back in my stance).
Once the saw is about 1/4 of its depth into the kerf (or a little less) and you have begun square, shift to the two-handed stance. You should be able to recognize any deviation of the cut stroke veering to your left or tilting of the plate top to bottom (but that isn't your error).
Whether Eastern or western, and as long as the error is to the waste side, squaring slight deviations of squareness is relatively quick with a plane.
Mike
Re: Ryobi question
Thanks Pam and all
roninkokomo
>It will be interesting to see if the dozuki is different. I have a dozuki that I have cut dovetails with for years.
As the error is on the waste side of the cut I can trim with the Lion, if I need to.
Thanks
Re: Ryobi question
Sawing around the perimeter.
dburnard
>I learned to saw with a pull saw by watching Jay VanArsdale (daiku dojo). Except on very thin stock he always tries to have the saw working in the kerf of two sides. So a very shallow cut into the top face starting at back top, and then drop the saw down along the front face of the cut. If you can follow the line on two faces (or three as the cut progresses) the cutting errors get much smaller. If not you'll get quick feedback since the saw will bind up in the misaligned kerfs.
He often rotates the piece the full 360, so all lines are sawn well before the middle is.
Doing this for a while will help reinforce where "vertical" is.
Re: Ryobi question
Re: Sawing around the perimeter.
>Not that I'm an equivalent to Jay, but I also get to sawing two sides as quickly as possible. Never thought of rotating the piece 360� though, will have to try it.
Pam
Re: Ryobi question
dburnard
>Yup, two sides especially the top and front make sense on a western height bench. On low horses it's the back and top.
360 rotation - for delicate work you get nice clean kerfs all the way around and if there are minor errors they are "inside" where they can be cleaned up easily, and/or they won't show.
Re: Ryobi question
>On a western bench I start the cut on the back corner (back and top), then quickly run over to the front corner (top and front), then alternate between them; so I guess it's three sides. On low horses, I don't recall.
Pam
Re: Ryobi question
wilbur
>I've found that for smaller cuts, and here I'm assuming we're talking about crosscut situations, going around the perimeter and cleaning up the interior is a good option for keeping the edges clean, as Dave mentioned. But for larger cuts I'll hit the top and front sides at once and going straight through*. I seem to get better results this way on bigger cuts, mainly because I tend to have to do less correction of the cut surface for some reason, even though those corrections will be on the outside and potentially more visible.
* Actually, I tend to start from the back and top corner, saw across the top until I get to the front top corner, like Pam, and then cut down from there, so maybe I do 2-1/2 sides. :@)
